There is a splined adjustment just under the handle of the 3175.
you need to remove the handle, usually held on with an allen screw
once you remove the handle, there will be a black "stop" held on with a screw, remove that, but remember its position.
once that is off you can adjust the temperature. there will be 2 white pieces, one has splines, you can move this counter clockwise one or two notches at a time untill you reach your desired termp.
be careful not to go too much, even though these are an anti scald valve, you are letting more hot water through it.
