20 Most Recent Rheem 40 GAL ELEC TALL Water Heater 6YR SC 82VH402 Questions & Answers
it is possible it needs a reset. 1. turn off the breaker to make sure there is no power to the unit 2. open the top cover and there will be a red button like this http://www.tonyhoover.com/wp-content/uploads/2010/03/water-heater-upper-thermostat.jpg push it. It may have a plastic cover over or around it, leave this in place it is insulation for the wiring.
close it up carefully and then turn on the power and see what happens.
Rheem 40 GAL... | Answered on Sep 19, 2019
71-408 is probably electric water heater.
Unknown brand, unknown type.
Water heater comes with product manual with step-by-step instructions.
Example instructions:
http://waterheatertimer.org/pdf/How-to-install-electric-water-heater.pdf
If this is under-counter model:
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Rheem 40 GAL... | Answered on Nov 05, 2018
Probably a faulty thermostat but a possibility, depending on design and area that heavy internal scale deposits are preventing the thermostat doing a good job.
Rheem 40 GAL... | Answered on Aug 03, 2016
You posted under typical Rheem tank-type electric water heater, but don't say what service you want to perform.
Listed below are typical actions one takes with electric water heater:
1) Flush tank each 6 months to prevent sediment.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html#flushelectric
2) Inspect and replace anode rod.
http://waterheatertimer.org/Replace-anode-rod.html
3) Test electricity from breaker box to water heater
http://waterheatertimer.org/Test-electricity-to-water-heater.html
4) Troubleshoot electric water heater
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
5) Clean sediment out of water heater
http://waterheatertimer.org/How-to-clean-sediment-out-of-electric-water-heater.html
6) Save money
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
7) Do it yourself information
http://waterheatertimer.org/Do-it-yourself-water-heater-timer.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Rheem 40 GAL... | Answered on Apr 04, 2016
There is no on/off switch. With the circuit breaker off you hook up the power lines to it, and then restore power. The thermostat will take care of turning unit on and off as water temps dictate.
Rheem 40 GAL... | Answered on Sep 04, 2015
the age of all water heaters is listed under the serial #, not model #. you will have to call a plumbing supply house that deals in your brand of waterheater, a.o. smith, ruud, bradfordwhite,etc.
Rheem 40 GAL... | Answered on May 19, 2015
You need to take 1/2 hour to learn basics and then test water heater parts before replacing anything.
Follow the troubleshooting steps, and it will tell you exactly where the problem is.
Otherwise we can guess at 20 different things.
Water heater is 240V because you have more than 1 element.
Did you test for 240V across top two screws of upper element?
Breaker can be tripped off on one leg and 120V arrives at water heater so heater looks like it has electricity, but circuit is not complete.
The problem can be loose wire, bad 240V circuit breaker, sediment reaching lower element, bad thermostat, bad upper element, tripped ECO reset button.
Did you replace factory insulation and cover over thermostats after replacing elements?
Did you vacuum out sediment when replacing lower element?
How long ago did you replace elements? If you turned power ON before tank was completely filled with water, then you burned out the element. If upper element is burned out, the tank has no hot water, even if lower element is good.
Test the upper element:
http://waterheatertimer.org/How-to-test-water-heater-element.html
See how a water heater works:
http://waterheatertimer.org/How-it-works.html
And finally, why so many folks write to fixya saying they replaced both elements and upper thermostat, but they never replace lower thermostat for another $6? I have been puzzled about that since lower thermostat turns on and off each time tank temperature drops and is responsible for keeping water warm during standby hours. Lower thermostat cycles more times than upper thermostat.
Add a comment if you need specific assistance with any of the testing steps.
Rheem 40 GAL... | Answered on Mar 14, 2015
The tank is leaking and in need of replacement or a connection at the top is leaking
Rheem 40 GAL... | Answered on Mar 10, 2015
You either have water with a high sulfur content or need to flush your heater. you should flush your heater every year anyway. you can turn off the water and electric to the heater. and totally drain the tank when it is totally drained add more water and drain some more. then refill the tank and run a hot water faucet the tub is best to eliminate any air in the system then turn the electric back on this should solve the problem if it does not you probably have sulfur in the water and would need water treatment or filters to help
Hello, dan
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about hot waterheaters and possibly yours, from
repair to trouble shooting it. http://home.howstuffworks.com/water-heater.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Rheem 40 GAL... | Answered on Feb 26, 2015
It will usually walk you threw setting up a google account when you go thru set up.. Otherwise, you can set one up at google: Create your Google Account After you have set up account on computer, go to settings on your phone, then accounts, then add a google account.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/perry_14036f9bc71cde6a
Rheem 40 GAL... | Answered on Jan 12, 2015
it does have 2 elements they are located under the 2 panels on the heater you will find them under the covers on the front they will be connected to the thermostats follow the wiring. besure to turn off the power before working on it and use a tester to double check
Rheem 40 GAL... | Answered on Jan 03, 2015
First, let me say that no Rheem electric water heater that I am aware of has only 1 element.
You may have to search - but there should be one about 8 inches from the top and another behind a panel about 10 inches above the bottom. Please search again.
It is NOT possible to add an element to a "used" water heater. The inner and outer liners must both be sealed and that is done at the factory.
Replace the relief valve & add an expansion tank.
Rheem 40 GAL... | Answered on Dec 13, 2014
Rheem 40 GAL ELEC TALL Water Heater 6YR SC 82VH402 Logo
359 questions posted
Top Rheem Water Heaters Experts
Donni Steen
Steve Allison
Steve Allison
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
