Freezers Logo
Posted on Aug 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Yesterday the door on my 14 cubic ft upright freezer did not stay shut tight (it was ajar about 1 inch for about 6 hours). When I became aware I closed and locked the door to be sure it stayed shut, but the freezer has run constantly since. The Model Number is 253.9244411 and it was bought 5 1/2 years ago. The food in the freezer did not thaw completely and everything is frozen in there now, but I am concerned that it continues to run.
Anonymous
Level 3:
  • Master 4,793 Answers
  • Posted on Aug 12, 2010
Anonymous
Master
Level 3:
Answers
4793
Questions
0
Helped
1544875
Points
14368
It may take upto24 hours to settle to -18C,remember it has to cool right through the food in the freezer,as well as the walls.also if the food went soft, it is spoilt......cook meat asap then refreeze.
My frigidaire freezer upright has an error message door ajar
Sounds like the main control board to the unit needed to be reset and with the resetting it has caused a communication error with the door sensor. Contact a service tech to move forward with a repair.
1helpful
Door ajar alarm keeps signaling with door shut and locked. What would cause this?
The door sensor causes that.
See to it the door really closely tight.
A dirty or defective sensor will fool the micro-controller to send an alarming.
Have it check and clean by a service technician.
Good luck.
The door ajar light and beeper keeps going off periodically. The light is out also. The motor is running and everything is frozen. The first time this happened, I moved items around and shut the door...
On electronically controlled units, a light out issue may alert you to a failure situation,(minor).. Replace the bulb and see if that was the fault
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
2answers
MAYTAG FREEZER CAPACITY
I cannot find a MQU8057AEW in the Maytag library. I did find a MQU2056AEW that is 20 cu ft.
Re: danby upright freezer 20.1 cubic ft., model #
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Oct 13, 2009 • Freezers
1helpful
Freezer door does not close tightly.
You can try replacing the seals and or adjusting the hinges.
That may work.
Be aware that if the unit is over 10 years old it is probably using twice as much power as a new one would and costing you an extra $75 to $100 annually to run over a new unit. Could be more than that if the door seals are not tight as well.
Top Kenmore Freezers Experts
Jay Finke
Jay Finke
ZJ Limited
ZJ Limited
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
