20 Most Recent
Maytag 20 cu. ft. Upright Freezer MQU2056B Questions & Answers
MAYTAG FREEZER CAPACITY
I cannot find a MQU8057AEW in the Maytag library. I did find a MQU2056AEW that is 20 cu ft.
What setting do I use to make the freezer freeze food
When you are freezing something, set your freezer on its highest setting. However, if you are going to leave your freezer empty for a long time, you should change the setting to a lower one. Here's a great tip for ice cream: place a tub of ice cream in a ziplock bag before putting it in the freezer; it prevents freezer burn. You know when your ice cream gets so cold, it's hard to scoop out? Doing this stops that, it's keeps the ice cream just soft enough for easy scooping!
Ice forms at the bottom
check for a bad/ loose/dirty gasket on the bottom side ofn the door. check your drainage line for clogging on the defrost system for back up
Things don't freeze on the
I would suspect the door seal is not making contact or has some defect in it. And that defect is probably in the top right corner of the door. If you have a thermomiter, wait until the compressor kicks in and then slowly run it around the door seal. There should be some area that is colder than the rest. If I am right, then you will need to replace the seal.
There is water leaking into the freezer and
This sounds like your Defrost drain is cloged. Do not chizel the ice. use hot water or a hair dryer to remove the ice. Now your either going to be lucky or a little unlucky. look at the back bottom area of the freezer and look for a hole the size of a dime. This is the defrost drain if you see it. If you don't then you will need to pull the power plug from the machine and remove the back wall of the freezer to find the drain. Then you can defrost the ice and then pour hot water down it the defrost that ice and get the drain clear. Its not good practice to shove things down the tube to clear the drain. you could break the tube. if you half to use somthing like a zip tie that is flexable.
Once the drain is flowing water your clear and can put the back wall back together. and plug the machine back in.
Keep in mind that you will need to remove the food and have a place for it while you are working on the machine.
one more thing. try not to pour more that 2 to 3 cups of hot water down the drain. The pan may not hold much more and will spill on the floor behind the machine.
Upright freezer
no light in unit??? check the bulb, reason i say that is you should aa least have lights on, check the recepticle its pulgged into
Refridgarator is not cooling
thermostats are usually a "on/off" switch just as a simple light switch. Ohms on a defrost timer is not very specific. It is basically a switch that turns heaters on and off while keeping the compressor off during the defrost cycle. Your thermostat may be sticking/hanging up.
ICE BUILD UP IN A MAYTAG MODEL MZF34X16DW UPRIGHT FREEZER
I have had a few of these, and others of the same ilk.
Your problem should be air leakage into the machine.
Take a thicker piece of paper, not cardboard, and try to slide it around the gasket where the door gasket contacts the front of the freezer.
The gasket should be firm enough to prevent the paper from sliding. Wherever you can move the paper, you could have a air leak.
Most of these have no adjustment in the latch to tighten the door. Sometimes a new gasket will solve the problem, sometime a new door will.
P.S. Twice I have tied a new freezer to a refrigerator dolly to move it and have accidentally warped the door, and they cannot be straightened. :-(
God bless your efforts.
Refrigerator not dispensing water or ice
repairs should be performed by a qualified technician. if there isn't ice in the ice bucket located in the freezer you have a water flow problem. if there is water going to the filter and nothing out of the freezer then you have a clogged freezer replace it. if these things are ok then yes it could be the electronic control. filter failure is a common problem.
