Hi
The washing machine is obviously
drawing too much current for the breaker to handle. This could be due to the
washing machine drawing more that it should or because the breaker cannot
handle the current the machine needs, coupled with the other machines on the
ring main. If the fuse on the plug of the washing machine does not blow, then it
could be that there are too many appliances on the ring main. The fuse on the
machine may not blow however, if the breaker has a faster blow time than the
fuse in the plug. Try plugging the washing machine into another ring main. Or
try plugging out all the other appliances on the same ring main and test it
out.
If the ELCB (Earth Leakage Circuit
Breaker) is tripping only when the washing machine is running then something in
the machine is faulty.
One common problem is the heating element. Over time they tend to crack and
when the water gets in, the ELCB will trip out. This can be problematic to
diagnose as offten the element will only trip after a period of heating. Bottom
line, if it is tripping the ELCB then it is dangerous and should be fixed
before any further use.
Please get back to us if you have
further query else please accept the suggestion.
Thank you for contacting fixya.com
When we on ElCB, its Trips Immediately, How Can i do Remedy Action?
Probably the defrost heater element blown and down to earth.Mine has the same problem. If you access the control module and disconnect the plug with the 2 larger brown wires and check resistance to earth ,any reading will show if that is the problem. Unfortunately I can't tell you how to access the evaporator to replace the element, I can't work out how to remove the plastic panels. Your fridge should work OK with the heater disconnected but will ice up the evaporator after a little while , Perhaps turning the power off overnight without opening the doors every couple of days might work.
