20 Most Recent KitchenAid KSRS27ILSS Side by Side Refrigerator Questions & Answers
It's most likely the tube that leads from the freezer to the drain pan for the defrosting cycles.
KitchenAid... | Answered on May 15, 2012
Water from the bottom of the refrigerator is usually due to a faulty door or gasket, a leaking drain pan, or a clogged defrost drain pan.
I will advice you check these areas to fix the problem.
KitchenAid... | Answered on Apr 12, 2011
ur valve can be leaking. id replace the water valve in the back
KitchenAid... | Answered on Feb 25, 2010
clean your evaporator coils under neath there full of lint!! and dirt also you evap fan under there is probably going out
KitchenAid... | Answered on Jan 14, 2010
The most possible 2 reasons for this is the water control valve part number 4389177 or the thermostat inside the ice maker is not working. If ice maker is empty pour tap water until full and lower arm to see if the ice freezes and drops. If this works I would replace the water control valve. Below is a link enter your model number or the part number in the model search feature. There you will see your refrigerator. Thanks Sea Breeze
http://servicepartstec.blogspot.com/
model number KSRS27ILSS02
KitchenAid... | Answered on May 29, 2009
Why not contact KitchenAid again and explain that you have performed the service checks their technician(s) should have performed and the bi-metal (switch) is at fault. Perhaps another visit from a competent technician or that technician's manager will result in success.
KitchenAid... | Answered on Jun 30, 2019
Get a rear earth magnet from Home Depot or online. Or buy one from Repair Clinic
https://www.google.com/search?q=magnet+in+Kitchenaid+refrigerator
KitchenAid... | Answered on May 28, 2019
Take the lower panel off the bottom of the refrigerator in back. Turn your refrigerator on and make sure the fan on the condenser coil is turning and check to see how dirty the coil is. If it's going out on over temp, it means you can't expel heat.
KitchenAid... | Answered on Apr 08, 2019
KitchenAid KSRS27ILSS Side by Side Refrigerator Logo
Popular Tags
9 questions posted
Top KitchenAid Refrigerators Experts
vince
geob91
Dakshinamurthy...
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Refrigerators
Most Popular Question
installing water line fridge
  • Refrigerators
