Computers & Internet Logo
A
Anonymous Posted on Jul 27, 2010
Helloi have A kingston 8GB datatraveller in green color.it is good in every way but if I copy A movie file in it and when I move that file to my pc then the file is not played.please do suggest me.thanks
Brian Sullivan
Level 3:
  • Computers & ... Master 27,725 Answers
  • Posted on Jul 29, 2010
Brian Sullivan
Level 3:
Answers
27725
Questions
Helped
5670316
Points
79191
Download windows media player to your 8GB data traveller and save the file in this
Why in my pendrive all the data we trancefer are come in shortcut
Probably you just copied a shortcut to the location of the files. You need to go back and verify whether this is the case.
My Kingston DataTraveler G3 8GB USB 2.0 USB Flash Drive (White/Yellow)'s data all got corrupted, and i a cannot do anything [copying, pasting, renaming, moving, etc.] with the corrupted files/data
Get data back is a file recovery program for flash drives, it may work for this, but if the files are corrupt you would then be recovering corrupt files.
2answers
My Kingston 8gb dataTraveler isnt changing its name when i rename it. what can i do?
check it write protecting lock in on simply off the write protection and change the name
you can also rename device during format or by internal command
label
1helpful
Where can I get instruction on how to use your 4GB DataTraveler - G3 - USB 2.0 ?
Hello Gwolk,
The Kingston 4GB DataTraveler Generation 3 (G3) USB 2.0 is a durable 4GB flash memory drive for use with both Macintosh and PC computers. It may be used to transfer files from one platform to another, or to carry files and small applications on a continuing basis. Having no moving parts, flash drives are exceptionally durable and reliable for years of use.Simple - just plug into any USB port
Kingston datatraveler 8G shows write protection error, contain a virus outorun.inf, cannot save, cannot be formated and cannot delete. Please help.
1. Open Notepad and do not write anything in it. Just go to File > Save as (save it with the name: autorun.inf)
2. Copy the autorun.inf file that you have created in the above step and paste in your "Pen Drives"
3. Remove your pen drive.
After removing the pendrive, re-insert in your PC. Now your anti-virus will not detect any virus in your PC. And Your pendrive is 100% safe to use.
1helpful
Kingston Datatraveler 2GB Failure
Try formatting the drive. Should be a problem with the file system.
How do I download my computer files onto a Kingston DataTraveler 110
Look for the DataTraveller in My Computer and then just copy and paste or cut and paste any files you want straight to the DataTraveler.
Right click on the file, select copy or cut (cut will move the file permanently, copy will just make a copy of it)
Right click the DataTraveler and paste.
Grand Canyon Tech
Grand Canyon Tech
