Am getting error message saying Incorrect port Detected.
"The printer is designed to work with USB cables only"
"The current software setting is not set to USB port"
Then it says
"make sure:
- You are using a USB cable
- The printer is set to USB port."
I am using a USB cable and the printer works on my other computer, so presumably printer is set to USB port.
HELP!
Hello!
Yes the problem is with your printer port setting, to view or to correct the printer port setting,
- go to CONTROL PANEL
- click or open Printer or Faxes
- right click your Lexmark printer and click properties
- a menu will appear, choose or click PORT tab
- at the Port tab listing, choose USB port and click ok after choosing the right port.
then you should be able to print properly after the right configuration.
Hope I was able to help.
there is no port tab after I click properties. Now what
Good Day!
May ask what Operating System you are using?
No USB port to click on
