20 Most Recent Dell 926 All-In-One InkJet Printer Questions & Answers
A friend of mine had a similar problem. Connected with cable but printer was set to WiFi. Said out of ink. Disconnected WiFi in options. Problem solved.
Dell 926... | Answered on Apr 14, 2018
seriously doubt that you have a battery operated printer.
Dell 926... | Answered on Nov 09, 2017
probably needs to be an OEM dell cartridge . they have put chips in them now so we consumers have to spend more for them
Dell 926... | Answered on Oct 10, 2017
You need to charge the printer head for the ink to flow. Check your printer for head cleaning option. This should fix it.
Dell 926... | Answered on Sep 27, 2017
Just scan or create the documents and save them as pdf files. Start your email & make them attachments.
Dell 926... | Answered on Sep 20, 2017
Unplug the printer fro 5 min's and see if it clears.
Dell 926... | Answered on Jul 18, 2017
Dial Dell Printer Tech Support Phone Number1877-778-8@9@6@9for online support. For further Info Click:https://goo.gl/RlPU1p
Dell 926... | Answered on May 03, 2017
Hi!
The Print Screen key on your computer doesn't really print the screen. What it does it take a picture of the screen, and puts it into your clipboard.
You can then Paste (Control-V) the image into a program such as Paint or Word.
Print Screen by itself does a full screen image capture.
Control-Print Screen only takes a picture of the topmost window.
I hope this helps.
Dell 926... | Answered on May 24, 2016
What application are you using to print text? Word?
Try a simple application, like Notepad or Wordpad, to print some simple two-liner text.
Does printer print ALL the text on left side or just the half of printable material?
Even if you are indicating that page size is correct, looks to me some problem with the selection of print area.
Dell 926... | Answered on Oct 03, 2015
1)right click the my computer icon
2)click properties and then click hardware n go to device manager.
3)uninstall all usb ports and then scan for hardware changes
4)ur pc will detect your printer and ask for printer drivers
5)re load drivers and your pc will communicate with your printer
6)for reloding install the cd follow the instructions on the screen and click next
7)restart when the printer is loded.connect the wires and cords properly.
Dell 926... | Answered on Mar 31, 2015
Anonymous,
How to Clean Your Printer's Rollers
  1. Turn Off Your Printer - Use the power button to turn off your printer. After it has successfully powered off, unplug it. You don't want any power coming into the machine while you are cleaning it.
  2. Let it Cool Down - Even if you haven't printed anything recently, you should still let your printer cool down for a few minutes. While it's on standby, it can build up a decent amount of heat. The last thing you need is to burn yourself while trying to clean its rollers.
  3. Remove the Paper Tray - In most cases, you will need to remove the paper tray in order to gain access to the printer rollers. This is usually as simple as pulling it right out. You will have to remove any paper that is in it first. If you're unsure about how to remove the tray, refer to your owner's manual. Don't force the tray out of your machine. You could inadvertently damage it by doing so.
  4. Remove the Ink Cartridges - This step isn't always necessary. If the ink cartridges stand between you and the rollers though, you will have to remove them. Simply remove them as if you are going to exchange them for new ones.
  5. Have Your Supplies Ready - You probably already have what you need to clean the printer rollers. A lint-free cloth is a must, and water will generally suffice. If you'd prefer, you may also use isopropyl alcohol. However, you should wipe the components down with water after cleaning them with the alcohol. If you don't, an oily reside could be left behind, and it could have a very negative impact on print quality.
  6. Clean the Rollers - Now it's time to get down to business. Lightly dampen your lint-free cloth with water or alcohol. Squeeze it out to ensure that it's not too wet. Hold the cloth in one hand and press it lightly against the first roller. With your other hand, gently rotate the roller until you have cleaned it all the way around. Be extremely careful. Do not use too much pressure. You might have to run it through a few times to remove all of the residue.
  7. Repeat for Each Roller - Simply repeat the same process for each printer roller.
  8. Get Ready to Print - Once you're satisfied that the rollers are clean and dry, replace the ink cartridges. Replace the paper tray and load it with paper. Plug the machine back in and power it up again.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
#iwork4dell
Dell 926... | Answered on Sep 11, 2014
there still a small peace in there some where.
Dell 926... | Answered on Jul 30, 2014
Inside printer when open righthand side You'll see a pad and set of brushes clean with clean rag, and run clean in printer options. Then run align cartridges. should solve problem. make sure when putting in ink you just snap in and not mess with after that.
Dell 926... | Answered on Jul 11, 2014
Dell 926 All-In-One InkJet Printer Logo
758 questions posted
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Dell Office Equipment & Supplies
Most Popular Question
mode 926 printer must in print
  • Office Equipment & Supplies
