20 Most Recent
Lexmark Z735 InkJet Printer Questions & Answers
Wont recognise cartridges
Try hard reset of printer electronics to restore factory defaults. Also reinstall the driver software and see if it now works fine. If still a no go try setting up printer with another computer. If same thing there then the printer definitely has a nasty issue. If so I do not think a repair would be cost effective.
Free software for lexmark Z735 printer
Please visit the Lexmark website to download and install the
Lexmark Z735 Printer Driver on your computer. Select your operating system
> click on "FILTER" > click on the driver under Recommended
Downloads > download and execute the file. Simply follow the instructions on
your computer screen to complete the installation.
Blue light keeps flashing on on switch
The flashing light could indicate either a communication problem
between one of your cartridges and the printer, a short in one of the
cartridges, paper jam or the cartridge carrier has stalled. Please follow
the steps below to fix the problem:
- Remove the sheets of paper from
the feeder. Make sure there are no foreign objects or debris in
the feeder.
- Open the printer cover and
remove both the cartridges.
- While the cover is open, ensure
there are no paper jams and the cartridge carrier is free
from obstructions.
- Close the printer cover.
- Re-brick your printer. Pull out
the power supply, black box where the power cord is plugged in at
the back of the printer, and put it back after 30 seconds.
- When the printer turns on,
reinsert one cartridge first.
- Close the printer cover and
check the light status.
- If light on printer is normal,
open the printer cover and reinsert the other cartridge. Check the
light status.
- Replace whichever cartridge is
causing the light to flash with a new cartridge. You can also try to
insert a different known working cartridge to determine if the other
is faulty.
- Load some paper. Try to print a
document again to verify that the problem is fixed.
Installation driver for lexmark Z735
Lexmark Z735 printer driver on your computer. Select your operating system > click on "FILTER" > click on the driver under Recommended Downloads > download and execute the file. Simply follow the instructions on your computer screen to complete the installation.
Just put new ink cartridge in my z735 printer, its
Take a look at my tip on cartridges it may save you a lot of time and money
http://www.fixya.com/support/r3845491-ink_cartridge
OR
Read on and see if any applies to you.
Check that you removed the protective tape. some cartridges have two of these pieces of tape one over the head and possibly on on the contacts to the printer.
If you recently re-filled or had the cartridge refilled or even bought one of the many cheaper replacement cartridges you should read on
Most modern cartridges have an ink level chip built on to them.
Should the level drop below 25% then most of these chips lock up and will not reset.
Re-filling them will have no effect
If you are lucky you should be able to find either a chip resetter around on the INTERNET or maybe even local
OR
Even better empty cartridges that never need to be reset.
The second option is my preference
I realise these are not for your specific printer but there are others listed on both those sites as well.
cheaper cartridge problems have been on the rise recently and that is for ALL makes of printer.
If you try to clean the contacts be VERY careful cleaning contacts and ONLY use isopropynol on a lint free bud or cloth.
Also be very gentle.
I have seen the contacts cleaned and cartridges ruined with other methods of cleaning.
Rubbing too hard can also cause a badly set chip to move making it inoprable.
I dont like full prices replacements either which is why I always provide the links
I usually reccomend that people take back any cartridge that does not work right from the get-go.
I dont know of anyone who has had a problem doing that be it a shop refill or otherwise.
No matter if I paid $1 or $100 for a cartrdige I would still expect it to work
Hope this gives you the information you need
Bob
EXMod
It would be very decent of you to consider the quality of our experts answers and judge them accordingly as you pass through FixYa.
Thank you
I need to install my Z735 lexmark to my computer
Lexmark Z735 Printer Driver on your computer. Select your operating system > click on FILTER > click on the printer driver under Recommended Downloads > download and execute the file. Simply follow the instructions on your computer screen.
Should you still need assistance, please leave a comment to my response and I'll get back to you.
Not im cd for anlured
Por favor visite el sitio Web de Lexmark para descargar e instalar el controlador de la impresora Lexmark Z735 en su ordenador. Seleccione su sistema operativo, descargue y ejecute el archivo. Siga las instrucciones en la pantalla del ordenador.
Nota: Esto se traduce utilizando translate.google.com.
I do not have the
Hi. You can download the drivers and software for your printer here:
http://support.lexmark.com/index?segment=SUPPORT&userlocale=EN_US&locale=en&productCode=LEXMARK_Z735_COLOR_JETPRINTER&page=product&frompage=null#1
Regards,
D
Je ne troune pas une
Note that Lexmark does not recommend using or refilled cartridges. Refilled cartridges tend to degrade print quality and cartridge performance. It is best to use only genuine Lexmark cartridges for your Lexmark printer.
You can try to reseat your cartridges into the printer. However, if problem continues, please replace your refilled cartridges with new genuine ones.
The blue light on my
It could be a slight communication problem. Disconnect the printer from the pc. Reboot the pc. Open the printer cover and remove the cartridges. Close the cover. Unplug and replug the printer into the power source to reset it. When the printer turns on, reinsert the cartridges. Reconnect it to your computer. Try to print again.
Hey,
were unable
Lexmark Z735 Drivers
LINK-1,
LINK-2From the above links, select the Operating System you have on your PC and download/ install the required drivers
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
