Hi Thanks for using FixYa. The issue seems to be with
the door lock assembly that has gone bad and should be replace, you can fix it
yourself if you know which part it is that should be replaced and yes the door
should come out to fix this. Please do accept the solution if the issue is
resolved or post a comment for further assistance. Thanks Rylee
i know the latch on the door needs to be replaced but how do i get to the lock latch on the machinei know the latch on the door needs to be replaced but how do i get to the lock latch on the machine
Please post back with the model no# of your Kenmore HE4 which is located along the door frame openingPlease post back with the model no# of your Kenmore HE4 which is located along the door frame opening
You can't post conmments that contain an email address.
If your car door won't close or stay shut then this quick free fix is just for you! ... It's a great day when you can prove to your child your not as old as they think you are :) .....It's pouring outside and my rear passenger door latch messed up. .... two doors and I couldn't shut them.. was worried I would have to catch the bus until we ...
? 4:24
https://www.youtube.com/watch?v=tQYWOK1q_iQ
Dec 22, 2012 - Uploaded by backyardmech
Fixing a stuck latch on a car door. Video shows that the door won't close, how to release the latch, the ...
Sounds as if your door lock has gone over the cam or faulty, first plug out appliance look into the hole in the top of the door and with something like a small screwdriver pull back the cam now when you go to close the door make sure the striker is in line with the lock, if the cam does not pull back you will need to replace the lock.
When you see the DE error code, it means a "door error". This is a sign that either the door is not shutting, locking or opening. Most of the time, this is a simple fix and service is probably not needed. Check for something stuck or lodged in door. Check door gasket. Check door latch.
you will need to remove the trim with the door shut ,the pop the lock with a screw driver to get it opened,it would be better if you took it to a mechanic
The problem is fixed replacing the door lock switch. In some less common case the defective part can be the wiring harness to door lock, or a defective electronic control.
try shutting off power and then turn on..If this doesnt work turn on self clean again ,start it then after a few seconds cancel. This should tell the lock to release.
this happened to me and it drove me crazy for a few days. check that the hood is closed tightly. its held shut for the most part by a peice of metal with a screw on one side, a spring around it, and a nub looking shape that fits into the locking device above the bumper. When i finally checked my hood, the entire bit of metal had come unscrewed and was stuck in the locking device, leaving my hood held shut only by the safety clamp. remove it from the locking part and screw it back into the hood, closing it a few times to find the right distance to screw it in. lock your car and hear that chirp, that should fix it
if thats not the case then check that all of the doors are closed nice and tight... if the doors lock but the audible alarm is not armed then that is most likely the case
INSIDE THE DOOR LATCH(WHERE DOOR CLOSES ON STRIKER)ARE THE DOOR ADJAR SWITCHES.SIMETIMES THEY WILL FREE UP IF U SQUIRT THEM W/ WD40.DO THAT TO EVERY DOOR AND SEE IF THAT HELPS.
try spraying it w/ wd-40 or graphite, work the lock back and forth w/ your finger or a screwdriver. it also could be that its in the locked position now, w/ door open pull handle and see if latch moves/ opens. if it does close door. if this doesnt work go to local junk yard and pick latch up for 50.00 bucks. hope this helps
