20 Most Recent Kenmore HE4t 3.8 Cu. Ft. King Size Capacity Plus Front Load Washer Questions & Answers
The most likely cause for your issue is excess debris in the pump strainer, or a bad impeller on the pump. If you have a front small trap door on the front left or right, follow the instructions in your manual for cleaning out the trap. If the trap is empty, or does not exist on the exterior, you may need an experienced repair man to open the machine up to get to the pump strainer and check the drain pump. Pleazer Appliance...
Kenmore HE4t 3.8... | Answered on Apr 19, 2014
Try drying the board with a hair dryer but not so hot to destroy the electronics. Place an ample amount of distance between the board and the electronics. Set aside for an hour, then try the machine.
Kenmore HE4t 3.8... | Answered on Jan 17, 2014
The error code F11 is actually a motor control unit (MCU) error and it has been found in many cases that its failure can interfere with the operation of other parts such as the central control unit (CCU) making it appear that the machine doesn't work at all. Unplug the machine for at least half an hour to eliminate the possibility of an electronic glitch. If the problem persists, verify this condition by disconnecting the MCU and starting the machine. The MCU has indeed failed if the machine seems to work fine except for motor powered functions such as spin and agitate. With the MCU disconnected, you can set the cycle selector to Drain/Spin then select No Spin in the Spin Speed selector. The MCU needs to be replaced if the drain pump works fine. The link below contains the detailed instructions in addressing drain problems. Indicate the exact model number of the machine should you need further help.
Error Code F02/F21 on Whirlpool Duet and Kenmore Elite Front Load Washers
Please accept the solution should you find it helpful and/or informative. Accepting the solution will not bar you from posting comments or additional information. You can still communicate with the expert should you need further advice regarding the issue stated herein.
Kenmore HE4t 3.8... | Answered on Sep 10, 2011
The Kenmore HE4T washer does not have a reversible door. The matching dryer would have a reversible door.
Some newer washers do have a reversible door but it is still a very small number of washer that allow you to reverse the door.
You can not reverse the door on an HE4T washer.
Kenmore HE4t 3.8... | Answered on Aug 21, 2011
F14 for Kenmore (Whirlpool) machines means EEPROM Error.
The Central Control Unit (CCU) receives it's data from an EEPROM on board the CCU, if there is an error reading this data, it will cause this error.
A power glitch may cause this error. Try unplugging the Unit for two minutes to see if that fixes the error. Check CCU. So its likely you'll need a new CCU board.
Check your owners manual, some models have up to a 5 year parts warranty on that CCU.
Kenmore HE4t 3.8... | Answered on Jul 21, 2011
It is recommended by the manufacturer that you leave the washer door open on all front loaders when not in use or the washer can develop odors, or begin to mold and mildew. Leaving the door open allows the tub air out. Because this is the lowest point of the drain cycle, gravity will always cause residual water to reside in the drain pump and drain lines. The water will NOT evaporate, but it will keep it from becoming sour. The following link explains what some of the common causes of odors in a front loader are and how to prevent them:
http://www.fixya.com/support/r3608512-getting_rid_front_loader_mildew_odor
Newer model Kenmore Elite, Whirlpool Duet and Maytag Epic have a "Cleaning Cycle" button on the front panel. The owner's manual will explain how to use this feature.
If you do not have a cleaning cycle, use the hottest setting you have about once a month with a small amount of bleach to keep the spin basket and wash tub sanitized. I recommend the "Whitest Whites" cycle set on the "Light". This cycle is only 48 minutes.
Read through the link provided and make sure you periodicallt check the drain pump for debris that can cause odors and make sure you are using the correct detergent. If you have any questions, please post back and let me know. I hope this helps you.
Kenmore HE4t 3.8... | Answered on Jun 18, 2011
f-11 door lock error
Kenmore HE4t 3.8... | Answered on May 13, 2011
you're using to much detergent,the machine can't pump out suds,it will start to fill and drain to get the soap out.take out the clothes,run it and after a bit hit the drain spin and see if it stops.using to much detergent is the number one killer of front load washers,the extra detergent eats at the spider gear and when this happens it's time for a new washer,you'll know when it breaks,when it goes into the spin cycle it will bang all around loudly,you should only be putting in 1/4 of a cup of H.E. detergent
Kenmore HE4t 3.8... | Answered on Mar 05, 2011
FH error indicates that either you have no water coming into the washer, or very little water. Since you can see it filling, the error indicates low flow. A flow meter
in the unit detects if 10.5 gallons fills the tub within 8 minutes; yours must not be. This will turn off the inlet valves and the error code will be displayed. Check the following:
- Make sure you don't have a siphoning problem. This occurs when there is no air gap for the drain line at the standpipe. The standpipe is the drain pipe at the wall where the washer drain line is placed. With no air gap, a vacuum is created, and water will begin to drain from the wash tub prematurely. To prevent this from occurring, follow this advice:
•The standpipe should be 2 inches in diameter to allow a sufficient air gap between the top of the standpipe and the drain hose.
•The standpipe should be a minimum of 34" from the floor, and should not exceed 72 inches in height.
•DO NOT seal the top of the standpipe. Many consumers seal the standpipe in the belief that this will prevent overflows, or get rid of drain odors. This often creates more problems than solutions.
•DO NOT place the drain hose too far down into the pipe. Water stays in the drain trap area of the standpipe. If the end of the drain hose rests in this area, no air gap is created, and this can also cause siphoning. 4 to 6 inches is sufficient.
•The drain hose length must not exceed 10 feet in length. Excessive drain hose length can cause drain problems and back wash.
- Verify Drain Pump operation. Unplug the washer and take the lower panel under the door off by removing the three screws under the bottom edge. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. Open the pump access and remove, once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there's nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
- Verify Flow meter operation and that the Pressure Switch hoses are intact and connected properly. Remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The flowmeter will be located on the left-hand side of the washer (facing from the front) between the inlet valve and dispenser. It's a small white plastic device with hoses attached. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a hose attached. There should be a tech sheet directly behind the panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics, how to locate the components mentioned, and the specific measurements required in determining if the components are good or bad.
"F/H" indicates that either you have no water coming into the washer, or very little water.
If you have NO water coming into the wash tub after 30 seconds the error code is displayed. Check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
If you HAVE water filling the wash tub, and after 8 minutes, 10.5 gallons of water has been detected by the flowmeter, but there has not been a detected a Pressure Switch trip, the inlet valves are turned off and the error code is displayed. Check the following:
- Make sure you don't have a siphoning problem. Click the following link for instructions: http://www.fixya.com/support/r587481-prevent_washer_siphoning
- Verify Flowmeter operation.
- Verify the Pressure Switch hoses are intact and connected properly.
To access the Drain Pump - UNPLUG the washer and take the lower panel under the door off by removing the three screws under the bottom edge. HINT: Propping the front feet of the washer up can make access much easier. I use a couple small blocks of wood. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. If not, click on the following link to check the pump for obstructions:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
To access the Flowmeter and Pressure Switch - remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The flowmeter will be located on the left-hand side of the washer (facing from the front) between the inlet valve and dispenser. It's a small white plastic device with hoses attached. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a hose attached.
There should be a tech sheet directly behind the panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics, how to locate the components mentioned, and the specific measurements required determining if the components are good or bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Kenmore HE4t 3.8... | Answered on Sep 18, 2010
The error is an indication a motor speed problem. You will need to check the following:
- Check the wiring harness. Verify all connections between the Drive Motor, Motor Control Unit (MCU), and Central Control Unit (CCU).
NOTE: The MCU is a circuit board located in the vicinity of the Drive Motor on the bottom rear of the washer. To access the MCU, you will need to remove the back panel of the washer.
NOTE: The CCU is the main computer for the washer and is located behind the wash tub. You will need to remove the top panel to access the CCU. This is accomplished by removing the three screws in the back of the washer that hold the top in place. Once the screws are removed, the top panel will slide back, then lift off.
- Check the Drive Motor. Perform a continuity check of the Drive Motor windings. Remove the connector plug and check across pins 1 to 2, 2 to 3, and 1 to 3. All readings should be approximately 6 ohms. HINT: You can also take this reading by removing connector 2 from the MCU and measuring across pins 1, 2 and 3. If the readings are good, this will also prove the wiring and connector good.
- Check the MCU. The connectors are numbered 1 to 3 (L to R). That is, with the MCU installed, connector 1 is on the bottom, followed by 2 in the middle, and 3 on top.
Connector 1 - is the serial communications link between the MCU and CCU and has three wires. At the opposite end, this will be the 2nd connector from the rear on the left-hand side of the CCU.
Connector 2 - is the link between the MCU and the Drive Motor. Pins 1, 2, and 3 on this connector are the Drive Motor windings. Pins 4 and 5 are for the tachometer.
Connector 3 – is the primary power connector. Pins 1 to 2 should read 120VAC with the door in the locked position. Pin 3 is ground. At the opposite end, this is the 4th connector from the right on the front of the CCU.
NOTE: All the connector pins are numbered R to L.
If your continuity readings are normal for the Drive Motor and you have verified all connectors, replace the MCU.
If any of the Drive Motor windings indicate readings higher that 6 ohms, replace the Drive Motor.
Kenmore HE4t 3.8... | Answered on Sep 11, 2010
Hi
Thanks for using FixYa. F/2 error means Long Drain. If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed. Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Kenmore HE4t 3.8... | Answered on Aug 23, 2010
Hi
Thanks for using FixYa. The issue seems to be with the door lock assembly that has gone bad and should be replace, you can fix it yourself if you know which part it is that should be replaced and yes the door should come out to fix this. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Kenmore HE4t 3.8... | Answered on Jul 19, 2010
Take the vent tubing off and inspect for heavy buildup of lint. There is a moister sensor that detects a clogged vent and shuts off the heat automaticlly. If the vent tubes are clean the sensor needs to be replaced .
Kenmore HE4t 3.8... | Answered on Apr 29, 2010
"FH" is a No Water Detect error. It is an indication that you either have no water coming into the washer, or very little water at all. The following link explains how to troubleshoot:
http://www.fixya.com/support/r3608753-fh_error_code
This is one of those error codes that can be tricky to troubleshoot due to the many potential causes of the problem. My adivce to you is to eliminate the easy common sense items first, such as making sure the water taps are turned on sufficiently, the inlet hoses aren not kinked, the water inlet valve is not clogged, you don't have a siphoning issue, and/or the drain pump is working.
For the more complicated potential causes, each one of these washers comes with a technical data sheet inside.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front feet of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it to troubleshoot this error code.
Read through the information provided and let me know if you have any further questions. I hope this can help you.
NOTE: If you have already verified the sediment screens at the inlet valve are clear, the drain pump is not clogged and all the hoses are clear and not kinked, you've narrowed it down to either a siphoning issue, pressure switch problem or a flowmeter.
Kenmore HE4t 3.8... | Answered on Mar 31, 2010
when you put it on to drain can you hear a noise from the pump to show its working, if it wont drain it wont spin, if you can hear the pump then there is a blockage somewhere could be in the pump, filter, outlet hose or stanpipe
Kenmore HE4t 3.8... | Answered on Mar 30, 2010
Kenmore HE4t 3.8 Cu. Ft. King Size Capacity Plus Front Load Washer Logo
43 questions posted
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
View Most Popular
  • Kenmore Washing Machines
Most Popular Question
washer flashes error code f 11
  • Washing Machines
