This problem is between waste ink absober full and ink cartridge.
Firstly your need to reset waste ink absober full.
Follow this step to reset waste ink absober full.
1> download iptool to reset waste ink absober full
Download here ----> Service tool 1
Service tool 2
After ypur download finish
> turn off your printer power switch
> open your printer cartridge door
> press and hold on/off button (never release)
> turn on printer power switch
> push your printer cartridge door switch with pen or anything can press that door swith.
> then release on/off button
> close open door
> then press on/off button 1 more
now your printer is in normal mode( no orange led blinking)
Then you can use ip service tool to permanent reset waste ink absober full.
IF after reset your waste ink absober full, problems still apppear error5100
> change your ink cartridge with the working cartridge
usually error e5100 due tow problems above
Hope this guide can help fix your problems
Extra download
Fixwasteinkabsoberflow
Very good way to settled my canon printer. Thanks a lot.
you're welcome
hehehe :) and do not forget to give a better Testimonials to improve my position in the chart of fixya.com, in this occasion I would like to represent you to give a lot thank to fixya.com for creating this space for us all to describe the problem relate.
thanks you fixya.
regards
multilinkent
- Timing **** strip film (QC1-6394)
- Logic board ***'y (QM2-3078)
Before replacement of the logic board ***'y, check the waste ink amount (by service test print or EEPROM
information print). If the waste ink amount is 7% or more, also replace the ink absorber kit (QY5-0146) when
replacing the logic board ***'y.
- Carriage motor (QK1-1500)
-Sheet feed unit (QM2-2916)
-Purge unit (QM2-2925)
