You will have to do a reset. Follow the instructions below
1. power off.
2. hold stop/reset, hold ON/OFF
3. release stop/reset, push stop/reset twice, quickly, then release ON/OFF
4. wait untill LCD display shows “Canon Idle”,then push stop/reset four times, quickly
5. then push power twice, quickly
6. power off and power on
Thanks a lot =) finally work in my canon mx 300 too, i have this problem but this was helpfull too, enter in a service mode and worked, first i restore to fabric with the method of unplug the electric cable and hold on/off then press reset and wait to apear shiping mode and then press > then press ok to print a page and then turn off.... then the error still apear but whit the solution of
1. power off.
the problem get solved....
thank uuuuuuuu!!!!!!!!! =)=)=)=)=)=)
SOURCE: Printer problem
The error means waste ink absober is full, you must have been doing alot of printing,
Every Canon Pixma has a certain number of pages and/or cleaning cycles it can go through before the waste ink pads are considered to be full.
I have not been able to find the number of pages to fill the waste pad anywhere, it might be in the users manual.
An actual number of pages printed would be more helpful, how many reams of paper have you run through it?
If that machine has a self test page it might include a page count. try the follow steps:
Turn on your MP110.
After that press: Menu - Scan - Copy - Scan.
It will enter in Service Mode.
Here I don't know exactly the procedure but may be something like that for mpc190/200 that follow:
Resetting the Waste Ink Volume Counter
1) Enter SERVICE MODE.---
By pressing Menu-Copy-Scan-Copy-Copy
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [OK] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Vote for me if this answer is approriate
SOURCE: check printer
Printer and computer is RAM base structure.
They cannot record any memory without battery.
please follow the steps with screwdrivers
1. Unplug the printer (NO power or any connection)
2. Flip the whole thing Up side down
3. At the bottom, you can see there are screws
4. they are for the generator of the power supply
5. Take them away
6. And slowly take away the "brown" box”
7. Then you will see a power cord links with printer
8. Use a very small driver to release it with real care
9. Leave it for 30 minutes
10. Put it back together .... done
After that
Also, from other, but work....
The reset procedure (for canon MP130) is:-
Turn on the machine
(1) Press MENU
(2) Press SCAN COPY SCAN to enter service mode
(3) USE > to got to NVRAM ACCESS
(4) set ABS-M LEVEL to 0
(5) set ABS-P LEVEL to 0
(6) Press STOP to EXIT
DONE !
