One of two things I can suggest:
1. make sure you are not scanning in JPEG or TIFF format as these are typically single page documents only. PDF is your best option for scanning.
2. Check settings, as some scanning software has an option that you can turn on or off depending on whether you want a single file with all pages or multiple files each containing a page.
You may want to "fan" the stack of papers (hold them firmly on one side of the papers and use the other hand to "fan" the other side) before putting in the tray. A lot of time the humidity causes the sheets of paper to stick together which causes the printer to take more than one sheets of paper. Also, make sure that you have plenty of papers in the tray.
For error e 1 4 = better take it out and wipe the smudgesfor error e 0 5 = check the ink catridge, when ciss installed most installer make mistake by making the red ink hole at the circle made on it. you must make the hole slightly under it, the small hole. the big round is under the thick plastic lid, so the pipe we put will make the catridge move from the original position. or your cartridge just spoilt.
Pls check below and re-list your exact error code and can help you.
Error Code : E2-2 = No paper (ASF) E3-3 = Paper jam E4 = No ink E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly E8 = Waste ink absorber full, or platen waste ink absorber full E9 = The connected digital camera / video camera does not support Camera Direct Printing E14 = The Ink cartridges whose destination are wrong E15 = Ink cartridge is not installed E16 ? Ink remaining is unknown E16 -E19 = Failed to scan head alignment sheet E22 = Carriage error E23 = Paper feed error E24 = Purge unit error E25 = ASF(cam) sensor error E26 = Internal temperature rise error E27 = Waste ink absorber full or platen waste ink absorber full E28 = Ink cartridge temperature rise error - E29 = EEPROM error E33 = Paper feed position error E35 15 = USB Host VBUD overcurrent error ? USB E37 17 = Abnormal motor driver error E40 20 = Other hardware error E42 22 = Scanner error1
Hold the button "Resume" (red triangle in a circle), click and hold "Power" - an indicator light green.
While holding the "Power" button, release the button "Resume".
Not releasing the "Power" button, double click "Resume" and release both buttons.
Four times click "Resume"
Once you click "Power", to confirm the selected action (reset counter absorber). Click "Power" again to turn the printer off and once again to turn it on.
