Polaroid 4011-TLXB LCD TV Logo
Posted on Jun 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Polaroid 4011-TLXB LCD TV (No video or audio - flashing red light
I have a Polaroid 4011-TLXB LCD TV and after about 2 years one day out of no where I turned it on and the blue light came on then went Red. No audio or Video - just flashes Red. Any suggestions as to what needs repaired?
Bud Martin
Level 3:
  • Master 11,361 Answers
  • Posted on Jun 22, 2010
Bud Martin
Master
Level 3:
Answers
11361
Questions
Helped
3368907
Points
33650
2helpful
2answers
I have a Polaroid 4011-TLXB and it won't turn on. I've read alot of people having this problem but mine is a little different. Most online articles I've read say that their tv turns on showing the blue...
U check the power supply board and it is good and power is on LED light power indication light up.Than only one possibility the tv Tuner signal board is shorted and dead.That the board,where the incomming broadcasting signal cable plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
I have a polaroid 4011-tlxb tv and when i turn it on the blue light comes on but no picture i have to keep turning it on and off untill i get a picture
It may have dying 24vdc power supply due to bad caps, check that first, it may cause more damage if you keep turning on and off.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Please post back what you find.
40''polaroid lcd(4011TLXB) has power to it but no pcture or sound? whats difference from power supply board and main control board
Power supply module is to supply voltages to the main control board (the board where the TV cable and video cables are connected to), backlight inverter board. You can buy the whole control box which has both board assembly (power supply and the main control board): http://www.shopjimmy.com/catalogsearch/result/index/?q=Polaroid+4011-TLXB+&limit=25
We were going to use our 4011-TLXB for a video conference and when we hooked up the computer the TV went blank. Now all I get is the red light. I know now that this a common problem. My question is which...
Does it work in TV mode?
It can be either the power supply is not putting out all the needed voltages, right now you only have the 5vdc standby voltage (because the RED lifght is on) or the backlight inverter board is bad, it is the board that drives the CCF lamps which is the light source for the screen, it may be bad or not getting the 24vdc from the power supply. worst case will be the main board that is not sending signals to turn on the power supply and the backlight inverter board.
If you are going to DIY and have proper tools and know safety precaution then please read on:
2answers
Polaroid 4011-TLXB Power supply blew up IC3 I need the generic IC nr. It is an 8-pin dip. It is switch mode driver IC. Please help. Larry @ central tv
Replace power supply board from PTS. No parts available for PCB.
Generic part nr for IC3 is A6252M can't find one easily.
I have a 40" LCD that sparked and will not turn on.
Turn it off and leave it off. It seems that your unit has some sort of major PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Polaroid 4011-tlxb. Power to tv and it was turning from red to green light when you press power button but no picture. Pressing any buttons on tv or remote and nothing was happening. Replaced power supply...
if you replaced the supply board then there is issues with the decoder board as you would need to chec kthat and see if its not the issue.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Polaroid 4241-TLXB wont stay on
I think I may have just solved this issue. Remove the back covers and turn the tv on until it the screen goes black. There will be a little red led that will light up when the screen goes black. right above that light there is 4 little swiches, the bottom one is labled BURN. Switch that one to the opposite direction. I don't know how but mine has been working for a couple days now with no issues. GOOD LUCK!
LCD television won't turn on
check the backlight inverters.
Top Polaroid Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
