20 Most Recent
Polaroid 4011-TLXB LCD TV Questions & Answers
Polaroid TV screen will not always come on.
Are you talking monitor rather than tv? I have an LG 22 inch monitor and the on off button is on the bottom, If I don't hit it right or just tap it, it won't turn off but flashes. Where do you have it plugged in? Is it with some other electronics, or right to the wall outlet? I'm really at a loss as to what your problem really is. Are you using the remote? One quick fix might be the battery's in the remote. If they don't have enough power, short or no signal will be sent to tv or not being able to decipher it.
2/5/2015 12:30:18 AM •
Polaroid...
Answered
on Feb 05, 2015
Have a 32 in polaroid hdtv and the color is all
Actually it sounds like your component cables need to be changed. If you are connecting with component cables please try another set (if you buy a new set like from Radio Shack make sure you can get a refund if that is not the problem and you need to return them).
3/8/2011 3:13:41 AM •
Polaroid...
Answered
on Mar 08, 2011
What would make the t.v have lines running
It could be any number of things. Try to use systematic diagnostics to trace where the fault lies. Start at input end of system to find out which bits work and which don't.
- Do you get a picture using a video recorder, dvd player, gaming console? If yes the problem is with your tv signal.
- Connect a different tv to your antenna / satelite dish /- can you get an analogue picture? If no the antenna (aerial) may be faulty
- Does the satelite receiver / digital terrestrial (e.g Freeview) receiver give you a picture on a different tv? If yes it could be either a technical fault with your tv or it needs retuning to the correct stations (enter setup menu and reinstall stations as per user instruction manual)
2/23/2011 10:24:11 AM •
Polaroid...
Answered
on Feb 23, 2011
I have a Polaroid 4011-TLXB
U check the power supply board and it is good and power is on LED light power indication light up.Than only one possibility the tv Tuner signal board is shorted and dead.That the board,where the incomming broadcasting signal cable plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
11/18/2010 6:40:47 PM •
Polaroid...
Answered
on Nov 18, 2010
Input connections are not working properly. Some
is your main antenna / cable (or cable box) connected to tv/monitor cable in...the monitor is on Ch 3...do you have dvd player or vcr...these devices must be set to cable / ch 3 also...and hook up to aux 1 or tv 2 depending on the jacks avail on the back of tv (please note if you are using a dvd recorder premium ch like HBO is and will be scramble)
6/14/2010 3:16:22 AM •
Polaroid...
Answered
on Jun 14, 2010
I have a 40" LCD that sparked and will not turn on.
Turn it off and leave it off. It seems
that your unit has some sort of major PSU
fault, or a problem that is shutting down the Power Supply Unit, PSU. This
happens so that no further damage, and possible fire will occur.
You need
to take the unit to a reputable service centre/man and ask for a firm
"Quote" for the work to be done.
1/22/2010 7:56:34 AM •
Polaroid...
Answered
on Jan 22, 2010
