Hello, I have a Frigidaire Gallery refrigerator model PLHS267ZA. The evaporator fan has stopped running, it shows no resistance so I assume the fan motor is bad. I have removed the fan motor, and put a house fan in the freezer until I can get parts. Now the water and ice maker is not getting water, the solenoid is working (one of them). Do you think there is more wrong than just the evaporator fan? Thanks for your help, Loren Brunger
As insignificant as it may seem, that evap fan motor is as important as petrol in a car. That fan controls the fridge cooling on many fridges and circulation in tha freezer compartment. Replace it with the correct one and you should see a functional fridge/ freezer again. Note, i wouldnt run unit without it for long, as condensig temperatures run high and compressors dont last long.
ANSWER Hello D. W. The error code that you are getting indicates a Evaporator fan 241509402 failure. You want to check the wiring at the fan motor and at the control board. Check for 12vdc to fan between red and brown wires. Check for variant voltage (depending on high or low speed) between yellow and brown. If it checks ok then replace the Evaporator fan. If error code still exists then replace main control board 5303918514. You can test this with a multi-meter TJMA-DMT3. Here is a link on how to use a multi-meter. http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/4810-how-check-continuity-ohmmeter.html
Hello friend, thank you for your post!
I understand that your evaporator fan keeps starting and stopping on your Frigidaire refrigerator, PLHS267ZCB2. It sounds like it could be an issue within the fan or control panel. Since it could be any one of these underlying issues I would recommend having a technician come out to properly diagnose your appliance. -Matt
Hello Claire Trancoso - If the refrigeration side is the one with the issue, you need to check the damper door/switch that is between both doors. In side by side units this damper controls the cool air from the freezer to come over to the refrigeration side to cool it. Contact a professional technician to diagnose if the unit has a floating restriction, an issue with the evaporator fan or a possible air leak.
You can get
required parts from from online sites like:
--- www.repairclinic.com or from searspartsdirect online site. --------- This
should help.Thanks.Helpmech.
