You would need a USB to SCSI (50 pin Centronics) adapter. That would get it connected, but i don't you are going to find any software or drivers that will then see the scanner so you could use it.
Hi there
I have found some details of the printer here http://pdf.textfiles.com/manuals/STARINMANUALS/Sony%20Security/UP-D50%20-%20Quick%20Spec.pdf
where it clearly states that the printer is SCSI based. This is not a usual printer interface, and it is highly unlikely that your Vaio will have a SCSI interface at all. However it does say "USB compatible with optional SCSI to USB converter cable" with a footnote "Window 2000/XP only" and your Vaio will almost certainly have a USB interface. Unfortunately the drivers on the Sony website here: Sony Global DP UP D50
only go up to Windows 2000/XP with no drivers listed for later versions of Windows, so you may have problems getting a driver to work.
But I think your major problem will be getting the cable to link the two. Sony's web site doesn't come up with anything and more general searches don't come up with a lot. My best suggestion is to determine the type of SCSI plug/socket on the printer and then go for an external SCSI adaptor (USB) with the appropriate plug/socket and then use an appropriate SCSI to SCSI cable to link the two. Without knowing more about your Sony's SCSI interface type I'm afraid I can't help more.
Hope this has been a little helpful
Cheers
I am very well versed in Canon scanners with many years of experience on them so I hope my advice helps you out. With any canon scanner that uses SCSI only 3 things can go wrong with them. First I would check the SCSI cable so see if the the connecting heads have pulled away from the cable and the tiny wires are exposed. If so one of the wires may be broken. Or possibly a bent pin on the connector. A simple test would be to replace the cable with a good working one. Then try the scanner to see if it will scan.
Second, the SCSI card itself, on boot up while your still in the boot screen you should see something like ADAPTEC SCSI and then some numbers. Or something similar depending on the manufacturer of your SCSI card. That particular scanner uses SCSI II. If you dont see the prompt window on boot up then I would go to item 3 below.
The last thing to try is item 3 and you will need to go into control panel in windows to do that. In control panel I would look device manager and then imaging. Under imaging if you have a yellow question mark your system does not recognize the scanner as being connected to the computer. If you verified that items one and two above are good and functioning correctly then I would disconnect the scanner via the scsi cable from the computer and reload the drivers for the scanner and then rehook up the scsi cable and reboot the computer. Then I would go back to control panel/device manager/imaging to see if the computer now sees the scanner if it does then you are able to scan again. If it does not, and you have confirmed that the SCSI cable and card in the computer are good and working and the drivers are installed correctly. Then it would be safe to say the SCSI port on the scanner is faulty. The scanner will need to be repaired then by a Canon technican.
There are two ways of retrieving data from a SCSI hard drive.
1. Connect the SCSI hard drive to a different SCSI connector on the same data cable, make sure this hard drive has a different SCSI ID from the first hard drive or other SCSI devices in your system. When you boot up your MAC you should see the second SCSI hard drive, You can then copy off your data or remove the redundant files and keep the old hard drive in your system as a 2nd hard drive.
2. Connect the old SCSI hard drive to a SCSI USB hard drive adapter. Then connect it to the USB port on the MAC and you should see this as an external hard drive.
Most HP's if they have a port for parallel, it is a special plug on the back that looks more like a SCSI plug. If your printer has this plug you need the special cable, otherwise you will need an adapter to convert USB to parallel.
As I recall, this is a SCSI device. Like many electrical connectors, SCSI connectors can develop a light corrosion which can keep the signals from being transmitted. The easiest way to clean such light corrosion is to shut down the Mac & power down *all* SCSI devices in the chain. Then gently unplug & replug all SCSI connectors. This will scrape off much of the corrosion & usually results in connectivity being restored. Be sure to unplug and replug the SCSI terminator attached to the last device in the SCSI chain. Restart by powering up the SCSI devices and finally restarting the Mac. Good luck!
If you can't connect iPod nano to your computer , make sure;
you have installed the latest iTunes software from www.apple.com/ipod/start.
Try connecting to a different USB port on your computer. Note: A USB 2.0 port is recommended to connect iPod nano. USB 1.1 is significantly slower than USB 2.0. If you have a Windows PC that doesn’t have a USB 2.0 port, in some cases you can purchase and install a USB 2.0 card. For more information, go to www.apple.com/ipod.
iPod nano might need to be reset (see page 64).
If you’re connecting iPod nano to a portable or laptop computer using the iPod Dock Connector to USB 2.0 Cable, connect the computer to a power outlet before connecting iPod nano.
Make sure you have the required computer and software. See “If you want to double check the system requirements” on page 68.
Check the cable connections. Unplug the cable at both ends and make sure no foreign objects are in the USB ports. Then plug the cable back in securely. Make sure the connectors on the cables are oriented correctly. They can be inserted only one way.
I'm not really sure what you're asking. If your problem is that your scanner has an "outdated" connector and you want to try to connect it to your PC via USB ports, the only sensible answer, given the prices of scanners, is to buy a new scanner. Your old scanner, if it is not USB, is probably a SCSI connector device. Do a Google search exactly like this "USB to SCSI adapter cable" and you'll see a lot of results. Cables generally seem to range from $20 to $100. Even if you get the scanner connected, there is a very high probability that there will not be any drivers available that will work with the new computer and cable. All-in-all, a new scanner, even a cheap one, is the way to go IMO, and will give you better scans to boot.
