20 Most Recent Apple HP Officejet G85xi InkJet Printer Questions & Answers
How can i send multiple fax pages in 1
1st you dail sending No. and then all the multiple pages on fax machine.
8/12/2009 10:49:58 AM • Apple HP... • Answered on Aug 12, 2009
I am trying to renstall drivers and software for HP OfficeJet G85
ok you can find the add and remove button in control panel to remove the older version.
go to start menu then control panel
4/2/2009 4:38:37 PM • Apple HP... • Answered on Apr 02, 2009
0answers
Carriage jam/officejet G85xi
SolutionStep one: Perform a power reset and connect the printer directly into the electrical outlet Remove all the paper loaded in the main input tray.
Make sure that the product is turned off.
Disconnect the USB cable from the back of the product.
Disconnect the power cord from the product.
Disconnect the power cord from the electrical outlet and wait 10 seconds.
Reconnect the power cord directly into the electrical outlet and check for the following.
Make sure that the power cord used is the one provided with the product.
If a computer is connected to the product, make sure that the computer is connected to a grounded (three-prong) wall outlet.
Make sure that the power cord is firmly connected to both the product and the power supply.
Reconnect the power cord to the back of the product.
Press the power button ( ) to turn on the product.
Reconnect the USB cable to the back of the product.
If the issue is resolved, proceed to Step six: Print a self-test page.
If the issue continues, proceed to the next step.
for more information please go to below link>>
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458822&cc=us&lc=en&dlc=en
Thanks for using FixYa.
2/3/2009 7:58:33 PM • Apple HP... • Answered on Feb 03, 2009
0answers
Alignment after new cartridge
Hi I think that you will need to clean the gold dots on the printer carriage or if not done so remove the blue tape from the cartridge or if you are trying to use refills install some originals as this may help.
Hope this helps'
Please rate me
Cheers J
11/7/2008 10:03:10 PM • Apple HP... • Answered on Nov 07, 2008
I want solution for my HP Offifejet G85
Here is a link to the HP website where you can download the manuals in the language you need. There are options for language on the G85 by entering your country code and the software has a language option also when you install it.
HP Officejet G85 manuals
HP Officejet software
You have the option to download the manuals and software in the language you want. If you continue to have problems just add a comment.
I hope this helps, good luck.
10/17/2008 1:59:39 PM • Apple HP... • Answered on Oct 17, 2008
Pages are not alined right.
I had the same problem about restarting. But then I switched from parallel to usb and everything worked again. Can't help on the crooked part tho. Sorry!
9/18/2008 4:13:00 PM • Apple HP... • Answered on Sep 18, 2008
Problems printing photos
please specify what printer, model,
7/24/2008 2:29:27 PM • Apple HP... • Answered on Jul 24, 2008
2answers
Are you using HP cartridges with the printer? there are known problems with non hp cartridges in hp printers.
7/21/2008 4:41:42 PM • Apple HP... • Answered on Jul 21, 2008
Are your hdmi wireless extenders apple compatible?
Consider the HRpart Wireless HDMI Display Adapter. Here are the key details: 4K Screen Mirroring: This adapter allows you to view audio, video, and office documents from a small device (like an iPhone, iPad, or MacBook) on a larger screen (TV, monitor, or projector) without messy cables. It's perfect for presentations, meetings, and exhibitions. Wireless and Easy Connection: Setting up this wireless HDMI adapter is straightforward. You'll need a 5V/2A power source (which can often be provided by a USB port near the HDMI input on modern TVs and projectors). If the port is occupied, a battery pack can also work. No Need for Wi-Fi: The adapter is self-contained and doesn't require an internet connection. Once connected to an HDMI input and powered, it displays a helpful screen for easy connection. You can stream movies, videos, games, and office files from your Apple device to a high-definition TV or projector. Compatibility: This device is more suitable for Apple devices, including iPhone models (such as iPhone 7 Plus, iPhone 8, iPhone XS, etc.), MacBook Pro, MacBook Air, and various iPad models (iPad Pro, iPad Air, iPad mini). However, please note that it does not support HDCP-protected applications like Netflix, Amazon Prime Video, Hulu, and others. You can find this HRpart Wireless HDMI Display Adapter on Amazon 1. Keep in mind that it's designed specifically for Apple devices and provides a convenient way to mirror or cast your screen wirelessly.
11/19/2023 5:44:49 PM • Apple Office... • Answered on Nov 19, 2023
Oce tds 860 error code 01101
Check if the fan on the Op panel side of the machine is running. Ensure the intake on left hand side of machine isn't blocked. Ensure rear vent on right hand back of machine is not blocked.
4/25/2019 2:44:15 AM • Apple Office... • Answered on Apr 25, 2019
WiFi connected to Apple MacPro
Have you set up the printer to print wireless? If so, if you have the computer and printer setup to work together, you should be able to turn the printer on and leave it on and print one job at a time. After it prints one job, it will stop and just be ready and waiting for you to send the next job. No need to turn off between jobs.
3/19/2018 1:50:46 AM • Apple Office... • Answered on Mar 19, 2018
,Printout has white horizontal streaks using win10 or my mini iPad, printer ok using Apple computer, while printing text. Color cart. Showing low ink, but was just replaced
When the ink is run past low (to empty) the print head can get damaged. You can also try 2 consecutive DEEP CLEANINGs .. See 'maintenance' in printer driver under advance setting s
1/6/2018 5:28:51 AM • Apple Office... • Answered on Jan 06, 2018
Why my pc is switched on but the monitor screen is blank?
Was the monitor turned off separately from the computer? The monitor does have it's own on/off switch. If it's all connected to a surge protector both would normally turn off at the same time.
10/21/2017 4:45:51 PM • Apple Office... • Answered on Oct 21, 2017
Apple HP Officejet G85xi InkJet Printer Logo
Popular Tags
14 questions posted
Top Apple Office Equipment & Supplies Experts
k24674
Kolbrun...
bvmihai
Are you an Apple Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
OfficeJet Apple
  • OfficeJet Apple
Most Popular Question
alignment after new cartridge
  • Office Equipment & Supplies
