20 Most Recent Apple HP DeskJet 3820 InkJet Printer Questions & Answers
My printer hp D1668 deskjet
try thisOpen the above cover by using screw driver and check the ribbon connecting wires tight them if they r losses and reassemble the printer again and try to print a page.Ur problem is solve Othewise replace it with new printer.By Vicky Twr on Dec 24,2011
12/24/2011 12:42:12 PM • Apple HP DeskJet... • Answered on Dec 24, 2011
I want to install hpdeskjet3820'how i can
You can download the HP printer drivers from their supportWEB site. Please click on this link and
select your model printer to download:- http://welcome.hp.com/country/us/en/support.html
8/20/2011 4:24:36 AM • Apple HP DeskJet... • Answered on Aug 20, 2011
WHERE CAN I GET THE SOFTWARE FOR HP DESKJET
Normal 0
You can download the printer drivers from the Compaq/HP WEB support/download page. Make sure you select your model printer and the XP or Vista Windows version of the drivers you require and install them. Click on this link to download the drivers: -
http://welcome.hp.com/country/au/en/cs/support.html
9/30/2010 5:32:25 AM • Apple HP DeskJet... • Answered on Sep 30, 2010
2answers
HP Solutions
visit support.hp.com
and download the latest software from hp.
9/21/2010 12:29:48 AM • Apple HP DeskJet... • Answered on Sep 21, 2010
Cant get my hp deskjet to print!
i have got my printer to work ,by connecting my photo copier in line
with my printer, thank you for your trouble..
Dennis...
12/15/2009 6:55:29 PM • Apple HP DeskJet... • Answered on Dec 15, 2009
Hp ink cartridge problem
Try to clean a the contacts on the carriage with piece of cotton and try again.
10/1/2009 12:26:18 PM • Apple HP DeskJet... • Answered on Oct 01, 2009
Hp deskjet 3820 - have refilled the cartridge and pc wont print
Clean the contacts on the carriage with piece of cotton and then clean the contacts on the cartridge with rubber and try again. If this not help replace the cartridge.
10/1/2009 12:16:53 PM • Apple HP DeskJet... • Answered on Oct 01, 2009
Need to find a power chord for hp printer 1610
Check the coltage and amperage of the power supply. You can then purchase a similar power supply with the same ratings.
9/8/2009 7:28:47 AM • Apple HP DeskJet... • Answered on Sep 08, 2009
HP Deskjet D4160
This is Vikram Kumar Thumu from India-Hyderabad. I have seen your issue and I would like to provide my solution on the issue.
Well, this is the issue that could happen with either with Printer Software or with Printer Ink cartidges that could be out of ink or very low in ink...
To isolate and to resolve the issue I recommend you to perform below solution. I hope that this will fix the issue for you.
Solution 1: Hard Reset Printer
1. Turn OFF printer
2. Disconnect Printer from Computer.
3. Remove the Printer Power Cable from wall outlet and then try to remove the ink cartidges from Printer.
4. Wait for a minute.
5. and then reseat the Printer ink cartidges and then Connect the Printer cable to the Computer and then Power ON Printer.
This should generally fix the issue. However, if the issue still persists then I recommend you to proceed further solution on the issue.
Soltution 2:
Right click on the Printer icon of HP Deskjet D4100 Series and then select the option " online " and then press F5 key in the keyboard. to effect the changes.
Solution 3:
Try to print a Cartidges Test page from Printer Properties to check the ink cartidges ink status.
if found issue with ink cartridges then replace them else try to uninstall and reinstall the Printer software.
This should resolve the issue. If the issue still persists then I recommend you to contact HP CHAT SUPPORT or HP PHONE SUPPORT team or HP EMAIL Support on this issue. They can help you further to resolve the issue for you.
If you need any further assistance you can mail me at [email protected]. I 'll be glad to help you ...
Bye.
9/1/2008 3:16:43 PM • Apple HP DeskJet... • Answered on Sep 01, 2008
4answers
Cartridges not moving
Sounds like a corrupt driver, uninstall your printer (Start> Printers and Faxes on right column), select your printer icon, right click>Delete. Disconnect your printer and re install drivers first, then reconnect printer when prompted. If still not performing correctly suspect printer head carrier fault.
8/16/2008 5:04:58 PM • Apple HP DeskJet... • Answered on Aug 16, 2008
Are your hdmi wireless extenders apple compatible?
Consider the HRpart Wireless HDMI Display Adapter. Here are the key details: 4K Screen Mirroring: This adapter allows you to view audio, video, and office documents from a small device (like an iPhone, iPad, or MacBook) on a larger screen (TV, monitor, or projector) without messy cables. It's perfect for presentations, meetings, and exhibitions. Wireless and Easy Connection: Setting up this wireless HDMI adapter is straightforward. You'll need a 5V/2A power source (which can often be provided by a USB port near the HDMI input on modern TVs and projectors). If the port is occupied, a battery pack can also work. No Need for Wi-Fi: The adapter is self-contained and doesn't require an internet connection. Once connected to an HDMI input and powered, it displays a helpful screen for easy connection. You can stream movies, videos, games, and office files from your Apple device to a high-definition TV or projector. Compatibility: This device is more suitable for Apple devices, including iPhone models (such as iPhone 7 Plus, iPhone 8, iPhone XS, etc.), MacBook Pro, MacBook Air, and various iPad models (iPad Pro, iPad Air, iPad mini). However, please note that it does not support HDCP-protected applications like Netflix, Amazon Prime Video, Hulu, and others. You can find this HRpart Wireless HDMI Display Adapter on Amazon 1. Keep in mind that it's designed specifically for Apple devices and provides a convenient way to mirror or cast your screen wirelessly.
11/19/2023 5:44:49 PM • Apple Office... • Answered on Nov 19, 2023
Oce tds 860 error code 01101
Check if the fan on the Op panel side of the machine is running. Ensure the intake on left hand side of machine isn't blocked. Ensure rear vent on right hand back of machine is not blocked.
4/25/2019 2:44:15 AM • Apple Office... • Answered on Apr 25, 2019
Apple HP DeskJet 3820 InkJet Printer Logo
Popular Tags
17 questions posted
Top Apple Office Equipment & Supplies Experts
k24674
Kolbrun...
bvmihai
Are you an Apple Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
DeskJet Apple
  • DeskJet Apple
Most Popular Question
get hp deskjet print
  • Office Equipment & Supplies
