20 Most Recent Apple HP DeskJet 840c InkJet Printer Questions & Answers
Service manual
The ink well in the printer looks like it has packed up this happend to me had to get a new printer
10/10/2014 8:24:36 AM • Apple HP DeskJet... • Answered on Oct 10, 2014
It prints fine using the new hp 15 black ink
it prints fine using the new hp 15 black ink cartridge. But when I print with the new color 17 cartridge, it comes out with uneven 'cross lines' of color, like sliced sideways.
3/18/2010 11:09:29 PM • Apple HP DeskJet... • Answered on Mar 18, 2010
2answers
After changing both cartrages the lower light keot
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
1/23/2010 12:54:26 PM • Apple HP DeskJet... • Answered on Jan 23, 2010
HP 840c Printer - Print quality problem.
I have no magenta trying second cartridge still same problem
1/10/2010 3:14:18 PM • Apple HP DeskJet... • Answered on Jan 10, 2010
My printer Hp 840c is not printing colour prints?
Friend try the utilities through cleaning nozzle check and head cleaning
7/16/2009 10:38:04 AM • Apple HP DeskJet... • Answered on Jul 16, 2009
ONLY TOP HALF ON BLACK LINE PRINTS, COLOR OK
I am experiencing the problem with an HP Officejet 7410xi.
5/2/2009 1:41:20 PM • Apple HP DeskJet... • Answered on May 02, 2009
0answers
I have an HP 840c
Mr.old..
I have the same printer and I've suffered this problem before,
I solved mine by replacing the ink cartridge
I used to clean the head using a smooth piece of cloth and hot water " real hot water"
that used to solve the proplem periodically and when I replaced the couple of cartridges the problem was solved totally.
If this did not work for you then try to replce the cartridge capint it selfe
if this did not work for you then try to replace the main board 'the mother board"
if this did not work for you then try to replace the whole printer.
if this did not work for you then try to replace the computer itself
if this did not work for you then try to replace the place you live in
if this did not work for you then try to replace the planet.
and good luck.
11/21/2008 5:22:40 AM • Apple HP DeskJet... • Answered on Nov 21, 2008
Printer will not print.
In your print utility, you need to calibrate your printer, which will print a test page and realign your cartridges. It should be OK after this. If not restart the printer and the computer.
8/16/2008 3:48:09 AM • Apple HP DeskJet... • Answered on Aug 16, 2008
2answers
Jammed deskjet 840c
IT IS VERY EASY TO REMOVE THE PAPER JAM. YOU JUST SEE THE BACK OF THE PRINTER A WHITE COLOUR ROUND NOB IS LOCATED JUST UNLOCK THAT NOB (LOCK AND UNLOCK ICON IS SHOWN BESIDE) PULL THE DOOR SLOWLY OUTSIDE REMOVE THE PAPER JAM GENTLY.THEN AGAIN FIT THE DOOR AS IT WAS AND REWIND THE NOB TO LOCK IT .DO THIS CAREFULLY AND U WILL GET SUCCESS.
7/28/2008 4:00:21 PM • Apple HP DeskJet... • Answered on Jul 28, 2008
Black printing problem
THERE MAY BE MINUTE PARTICLES OF DUST GOT STUCK ON THE CIRCUIT OF YOUR PRINTER IN THE CARRIAGE WHERE YOUR BLACK CARTRIDGE IS FIXED REMOVE YOUR BLACK CARTRIDGE FROM THE PRINTER AND GENTLY CLEAN THE CIRCUITS OF BOTH YOUR PRINTER AND CARTRIDGE WITH THE HELP OF VERY MOIST CLOTH OR TISSUE.THIS MAY HELP YOU. GOOD LUCK.
6/3/2008 10:20:26 PM • Apple HP DeskJet... • Answered on Jun 03, 2008
Printer has suddenly stopped working
thinks theres a jam
11/7/2007 11:40:59 AM • Apple HP DeskJet... • Answered on Nov 07, 2007
2answers
Hp deskjet printer
Download the driver for your computer and that printer, or run the cd. If you are on a mac and have osx, the drive should be in the os. If not, DL it with the printer disconnected. Launch the installer and then go to system preferences and choose PRINT/FAX. See if it's been configured properly.
10/23/2007 12:53:23 AM • Apple HP DeskJet... • Answered on Oct 23, 2007
Are your hdmi wireless extenders apple compatible?
Consider the HRpart Wireless HDMI Display Adapter. Here are the key details: 4K Screen Mirroring: This adapter allows you to view audio, video, and office documents from a small device (like an iPhone, iPad, or MacBook) on a larger screen (TV, monitor, or projector) without messy cables. It's perfect for presentations, meetings, and exhibitions. Wireless and Easy Connection: Setting up this wireless HDMI adapter is straightforward. You'll need a 5V/2A power source (which can often be provided by a USB port near the HDMI input on modern TVs and projectors). If the port is occupied, a battery pack can also work. No Need for Wi-Fi: The adapter is self-contained and doesn't require an internet connection. Once connected to an HDMI input and powered, it displays a helpful screen for easy connection. You can stream movies, videos, games, and office files from your Apple device to a high-definition TV or projector. Compatibility: This device is more suitable for Apple devices, including iPhone models (such as iPhone 7 Plus, iPhone 8, iPhone XS, etc.), MacBook Pro, MacBook Air, and various iPad models (iPad Pro, iPad Air, iPad mini). However, please note that it does not support HDCP-protected applications like Netflix, Amazon Prime Video, Hulu, and others. You can find this HRpart Wireless HDMI Display Adapter on Amazon 1. Keep in mind that it's designed specifically for Apple devices and provides a convenient way to mirror or cast your screen wirelessly.
11/19/2023 5:44:49 PM • Apple Office... • Answered on Nov 19, 2023
Apple HP DeskJet 840c InkJet Printer Logo
21 questions posted
Top Apple Office Equipment & Supplies Experts
k24674
Kolbrun...
bvmihai
Are you an Apple Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
DeskJet Apple
  • DeskJet Apple
Most Popular Question
service manual
  • Office Equipment & Supplies
