If the buttonhole lever on your Husqvarna Viking Jade 20 sewing machine is not lowering enough to reach the buttonhole foot, it may be misaligned or not properly adjusted. Here are a few steps you can try to troubleshoot the issue:
Check the Buttonhole Foot: Ensure that the buttonhole foot is properly installed and in the correct position. If the foot is not positioned correctly, it may interfere with the buttonhole lever.
Check the Buttonhole Lever: Inspect the buttonhole lever for any damage or debris that may be causing it to get stuck or misaligned. Clean the lever and surrounding area with a soft, dry cloth.
Adjust the Buttonhole Lever: You may need to adjust the position of the buttonhole lever to ensure that it aligns with the buttonhole foot. Refer to your sewing machine's manual for instructions on how to adjust the buttonhole lever.
Contact a Professional: If you are still experiencing issues with the buttonhole lever, it may be best to contact a professional sewing machine repair technician who can diagnose and fix the issue.
It's possible that other users may have experienced a similar issue with the buttonhole lever on the Husqvarna Viking Jade 20 sewing machine. You may want to search online forums or communities dedicated to sewing and sewing machine repairs to see if there are any helpful tips or solutions.
I don't see any reason to use a walking foot for sewing a buttonhole. The purpose of a walking foot is to move the top and bottom fabrics together. Feed dogs sometimes tend to move the lower fabric faster than the top fabric--a walking foot helps prevent that.
If you don't have a buttonhole foot for your machine, you can still stitch a buttonhole using a different presser foot.
It could be that 8mm is the limit for the buttonhole foot. You can try making buttonholes manually with the sewing machine. Not really difficult. Just need to be careful marking the buttonhole and stitching. Recommend practicing on scrap fabric before trying it on the project.
1.Mark position and length of buttonhole on fabric.
2.Set button on the base and slide base forward to secure button.
* If button does not fit on the base, adjust slide on base to diameter of button plus thickness of button.
a= Length of button + thickness
3.Pass upper thread through the hole of buttonhole foot and attach buttonhole foot to machine.
Bring upper and bobbin threads to the left under foot.
4.Position fabric under presser foot so that the center line mark is in the center of the needle opening in the buttonhole foot. With the main part of the foot pushed to the back, lower the presser foot lever.
5.Lower the buttonhole foot lever so it is positioned behind the raised finger on the foot (see step 5 illustration). a
Note:Machine will not start to sew if buttonhole lever is not lowered properly or buttonhole foot is not positioned correctly.
Note:If machine does not reset for second buttonhole, be sure the presser foot raised finger is pressed against the lever.
6.Hold upper thread lightly and start the machine.
Ref. :babylock.com/downloads/manuals/
The method will depend on your make & model machine, although the vintage sewing machine buttonhole method will work on all zig-zag machines (just requires manually measuring and adjusting the stitch length & width during the process):
do you have a manual? do you have the buttonhole lever pulled down? if these suggestions don't help then the machine needs to be checked at a sewing machine shop
the buttonhole foot snaps on to the presser bar, there's a little lever at the back of the presser bar that releases the foot, then put the buttonhole foot down on the needle plate & use the presser foot lifter (number 11) to lower the presser bar down onto the buttonhole foot & you'll hear a click sound when it snaps on & make sure to use the buttonhole lever(number 31) because the machine won't sew a buttonhole unless that lever is pulled down.
if you have a automatic buttonhole , then you should have a buttonhole lever that you have to pull down, before you start to do the buttonhole,, my machine will not let me do a buttonhole unless I pull down the buttonhole lever
Your machine should have a special buttonhole foot which has a place to insert a button, You will probably have to pull on opposite ends of the foot to open it. Place the button in the foot and then squeeze it together to make the button secure. Attach the foot to the machine. It should snap on. looking at the left side of the machine you will see your needle bar at the front and the presser foot bar at the back. You should also see another lever which needs to be pulled down so that it rests in the buttonhole foot.Select buttonhole on your machine and it should sew. The button determines how long the buttonhole is. Sewman7
