20 Most Recent White Sewing 1418 Mechanical Sewing Machine Questions & Answers
The needle won't move ...
www.whitesewing.com try there web site
10/18/2018 7:15:13 PM • White Sewing... • Answered on Oct 18, 2018
4answers
More questions about tension
can i get the exact model number and details of ur device
10/10/2017 10:05:02 AM • White Sewing... • Answered on Oct 10, 2017
2answers
Why does bobbin thread keep snagging?
increase the needle thread tension up a bit as it is too loose to pull the bobbin thread up properly keep adjusting until both threads are at the middle of the materials being sewn
3/25/2016 4:47:55 PM • White Sewing... • Answered on Mar 25, 2016
2answers
My needle arm is stuck in the down position, won't raise manually. Newbie
Not knowing the brand and model of your machine makes diagnosis difficult. In most machines that have the bobbin case inserted from the front, you can try releasing the bobbin case and removing it. When my machine jams, removing the bobbin case releases all those threads that are twisted and knotted inside that are "holding the needle captive." ...
10/4/2015 6:47:28 PM • White Sewing... • Answered on Oct 04, 2015
Bobbin winder screw broken, how to replace?
Until you can get your bobbin winder repaired, I'd suggest picking up a bobbin winder at your local fabric store. The last time I noticed, they cost about $30. Many sewists prefer to use this little accessory inside of wearing out the bobbin winder on their sewing machine. Also, if you more than one thread cone, you can rewind bobbins without unthreading your sewing machine.
2/23/2015 9:59:49 PM • White Sewing... • Answered on Feb 23, 2015
Is it o.k. to use
Up to a point it is OK to use a heavier thread on the top with your regular thread on the bottom. If you go too heavy with the thread you might notice thread locks on the underside of material. Tightening the the tension on the top thread will usually solve this issue. However if thread is too lheavy you will not be able to adjust for tension issues. You may also find that a "too" heavy thread will catch under the throat plate. Good luck.
8/23/2014 8:46:53 PM • White Sewing... • Answered on Aug 23, 2014
Babylock denim pro
I'm not sure what you've actually got, since your question mentions two different machines. Straight stitch is typically the default setting (the thing that comes up automatically) on computerized or electronic machines. On other machines, there may be an indicator for straight stitch (often stitch 0 or 1 if numbered), or it may be a zigzag stitch of width 0, length whatever.
5/25/2014 3:28:16 AM • White Sewing... • Answered on May 25, 2014
The feed dog moves, but doesn't seem to move the material through
try adjusting the bar that the presser foot is attached to , check in your manual for the instructions to do the adjustment..
5/7/2014 1:23:32 PM • White Sewing... • Answered on May 07, 2014
Is there a raise/lower adjustment for the feed dog on a white 1418
try this link and see if this is the right manual and see if the information is in manual that you need http://www.singerco.com/uploads/download/1075_white-1418-x.pdf
4/30/2014 7:32:31 PM • White Sewing... • Answered on Apr 30, 2014
Tension settings
Some general suggestion - not familiar with White. If you know where the tensioner is, take a scrap of relatively stiff cloth in a constrasting color to the thread to make it easier to see. A good stitch tension will look like a line of adjacent dashed on top and dash-dot-dash on the bottom. If you are seeing dash-dot-dash on top and Dash-dash on the bottom, the tension is too tight. If - usual case - the bottom has dash-loopyloop-dash, or worse, snags, the tension is too loose. Remember tension may need to be adjusted for thicker or thinner work.
1/20/2014 10:25:27 PM • White Sewing... • Answered on Jan 20, 2014
White Sewing 1418 Mechanical Sewing Machine Logo
151 questions posted
Top White Sewing Sewing Machines Experts
ZJ Limited
ZJ Limited
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • White Sewing Sewing Machines
Most Popular Question
needle arm stuck in down position raise
  • Sewing Machines
