20 Most Recent
White Sewing 955 Mechanical Sewing Machine Questions & Answers
Hello. I've have a problem
I've looked at your manual and do not see the buttons that you are referring to, what buttons are your pressing? Are you sure of your model number? I want to help you but I need more detail. I have 50+ years of sewing and feel if I do know the whole problem that I can help you, but I have to have the details.
BROTHER SUPER ACE II 955
I found an instruction manual for my brother ace on an australian brother site..hope this helps Pat
SENSOR KEYPAD SHEWING MASHINE BROTHER
Had the same problem here. Took it apart and found that several tracks in the ribbon cable from the keypad to the circuit board on which the LCD display is mounted were broken hence keypad needs to be replaced. Its part number is XA4331002 and available online from Sewing World. Have just finished fitting the replacement and keypad and sewing machine are working A1 OK.
My needle won't move the
Thanks for using fixya, Needle won't move due to following reason:-
1) Bobbin winder shaft was left in winding position. Please move bobbin winder shaft back to the left position and it will release the bobbin winder.Then you should be able to sew
2) Buttonhole lever was not lowered when machine was placed in buttonhole mode.You have to lower buttonhole lever.
3) Presser foot is up, Lower it.
4) Upper thread has run out, Thread machine.
Good Luck...
