Necchi 3537 Mechanical Sewing Machine Logo
Posted on Apr 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a necchi model number 537fa. the light comes on but the pedal and motor isnt running. you can manuely move the needle up and down, but the machine isnt running. could it be a belt?
Douglas Plant
Level 2:
Champion:
  • Expert 222 Answers
  • Posted on May 07, 2010
Douglas Plant
Expert
Level 2:
Champion:
Answers
222
Questions
Helped
64185
Points
402
If it is a belt problem, you should be able to hear the motor running. If you cant hear the motor running then it has to be the foot control or cord or possibly the motor.
1helpful
Hi, I just got a Necchi #537FA it has never been used , however it has sat for some time the light comes on ,the belt runs, the bobbin will run but the nettle seems to be locked up will not move
It's an older mechanical machine that has not been used for a long time and probably has not been cleaned or oiled. It is seizing from old dry oil. Avoid using the machine until it has been oiled or the motor could be damaged.
Wheel on right side that controls the needle up and down is very tight...
3helpful
3answers
I have a Necchi model 537FA. When u step on petal, it won't move. Does this machine have 2 BELTS? I only see one. I have oiled before running.
If you don't have any movement or hear the machine attempting to sew, you may have a burnt out pedal.
You should hear a slight hum when pressing on the pedal. If you don't hear a hum, the pedal is probably dead.
These can usually be ordered from the merchant who sold you the machine.
1helpful
2answers
I need a manual on a necchi 535fa
Try this web site:
http://www.sewingpartsonline.com/needle-threader-singer-503277.aspx
My Necchi 537fa is sewing sluggish. Motor spins but needle moves slow. What do I do to fix this?
If your Necchi has an external motor, take the belt off and run it.... is the motor sluggish? If so... that's where you start. motors need to be oiled, typically with oil and grease ports on either end of the motor housing.
If the motor spins up nicely,... you need to clean and oil the rest of the machine. Start underneath if the bottom workings are exposed, oil all the places where metal joins metal. Then do the bobbin and feed dog area... then look along the top and sides for oil parts.. give them a drop or two...Finally, see if you can get into the head where the take up lever and such are... oil the needle bar, presser foot bar, etc.
It's a dirty job... so prepare a good space for your machine. Liquid Wrench will help you free up gunked up and rusty parts. Fine grade steel wool (0000) and Cotton swabs help.
Good luck
2helpful
2answers
Replacement bulb for a Necchi 537FA
it's the same size as a night light bulb. That's how I replaced mine. You can pick one up at any hardware or dept store.
Top Necchi Sewing Machines Experts
vince
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
