LG 50PX4DR 50 in. Plasma TV Logo
Posted on Apr 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My on screen TV guide no longer works, and my TV keeps losing time (between 10 and 20 minutes). I'm not sure how to fix this. Is this a hardware issue or a settings issue? Has someone else had prior experience with this?
Steve LaHuis
Level 2:
  • Expert 418 Answers
  • Posted on Apr 14, 2010
Steve LaHuis
Expert
Level 2:
Answers
418
Questions
0
Helped
106428
Points
974
Do you have cable TV? Many Cable TV companies have recently (over the last year or two) quit sending TV Guide data. You can get it through an external antenna connected to the TV's antenna input if you are within range of an ABC or NBC and a PBS affiliate for the clock auto set.
But if you still have TV Guide service, some of these have failed circuit boards for the TV Guide, ( usually shows a complete black screen when you turn it on or hit guide button.
2answers
Why does it keep loosing Wi-Fi connection?
I
is your wireless connection dropping? - We Rock Your Web
www.werockyourweb.com > Tech > Troubleshooting
Jun 22, 2014 - The symptoms are a wireless connection that literally will drop out .... the 5th router is wireless CPE AP, wifi signal keep droppings all the time I ...
WiFi problems! Keep losing connection! - Tom's Hardware
www.tomshardware.com/.../wifi-problems-losing-...
Tom's Hardware Guide
Nov 15, 2015 - 9 posts - ‎5 authors
Ok so for some reason ever since we got a new modem and router my HP laptop willhave a full connection and all of a sudden ill lose it and my wifi says "No Networks available" and a red X appears by my bars at the bottom. ... I dont know if maybe my network adapter is going bad or ...
A fix for my Windows 8
I have a Tv Philips model 32PW6506/01 few minutes after that is between 10 and 20 minutes go stand by, then if I press p + start and after 10,20 minutes and goes into standby ...If anyone knows about...
Good day!
Usually that problem is cause of the failing capacitors on the power supply section.
You have to do is open the back cover of your TV and look for the actual image of the capacitor with in the power supply section if it is leak/bulged on the top.Please replaced it with the same type,ratings and value.
Thank you and good luck.
I have a Sony Trinitron 32" tv. When I turn it on, it has started taking longer and longer for the picture to come on. Sound is fine. Now once the tv is on for a while, the picture goes black for...
Yes.... u must adjust the screen voltage going to picture tube....located on the CRT module>>>little board connected directly to picture tube (take back off TV and you will see ) play around with screen control on the CRT module......can be adjusted at times to keep from losing picture!!! tube is bad...i know sure looks good when showing a picture....TRY adjusting screen voltage ( YES while TV is ON>>>CAREFULL ) gl
4helpful
3answers
Cannot remove tv guide banner from Sony bravia 52'
Click on the display button (upper left corner) as a short term fix - it will turn it off immediately - not sure of how to permanently solve this though.
According to Time Warner cable I no longer have TV Guide On Screen because the PBS piggy back signal is no longer being sent. Apparently, PBS is getting ready for HDTV. I live in Wilmington NC and we went...
PBS in my area says that my cable provider, Time Warner is no longer using the analog signal that contains TV Guide On Screen info. They did this to prepare for digital in Feb. Time Warner says they are waiting for Gemstar/Macrovision to provide a method for the On Screen feature to work. My source at PBS reckons there are over 25,000 cable card TV's that may lose this On Screen Guide. Apparently there is no legal requirement for TV Guide or your cable provider to send the guide.
Users may want to try and contact TV-Guide/Gemstar/Macrovision directly at their toll free number
1-800-386-7380. This may not be a solution but it may be a consolation for users wanting to know why they have lost their TV Guide On -Screen.
12helpful
4answers
Samsung E250 white screen
Hello if you want you could get it repaired or type *#8999234*348# it restarts inside the phone so u will lose all your data on phone like games music pictures videos and phone book but it will fix it or pay $80 dollars for new screen if you want more help my email is [email protected] and i fix phones all time i fix them my self pay $80 or come to me ill fix it for $25 plus warranty if it stuffs again. The white on screen means it forgot what was happening and just froze white and restarting by the code, Not just turning it of by holding red button, full restart by typing the code in the call screen any more worries about mobiles send me a email.
2answers
Onscreen TV Guide
The same problem occurred on my TV about the same time. I would be interested to know if you ever found a solution.
Guide Plus feature not working.
hi call your service provider and tell all this they will fix it or send you a man good luck
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
