20 Most Recent LG 42LC2D 42 in. LCD HDTV Questions & Answers
Hi.
You need to reach the Option menu, and to set the language. You will have to do this working on the Korean menu. I hope that the pictures below may help:
Press MENU button on remote, and go to OPTION menu, which is the one with a tag picture, right on top of the padlock pic.
Use the arrow buttons to select language. use arrow right to confirm and up and down to select.
Below a manual for this model:
LG 42LC2D
Regards.
Ginko.
LG 42LC2D 42 in.... | Answered on Dec 16, 2018
My LG TV stopped responding to the remote. A very helpful repair technician told me to stick a head phone jack in the sensor jack on the back of the TV a few times to clean out the contacts. Now the remote control works fine.
LG 42LC2D 42 in.... | Answered on Nov 18, 2018
Found that TV started switching off by itself. Would try to come on..green light blinked for 2-3 seconds, tv came on (with picture and sound) for 1 or 2 seconds and then it would turn itself off. Found that the issue is with one channel only. If you are facing this issue....try quickly changing the channel the moment it comes on. You can do it either with remote or with the TV buttons directly. also in the same logic, if this is still happening, try changing the source to another (rgb-pc, av1, av2 etc). Basically change it from whatever input it is on currently, if changing the channels does not work. My symptom was that the tv made a loud 'TIK' 'TAK' sound which is louder than normal.
LG 42LC2D 42 in.... | Answered on Nov 15, 2018
Believe it or not...THIS WORKS!!!!
 Look on the back of your set for an external remote jack. It should be the same size as a small headphone jack. If it has one, use a spare headphone plug or your headphones, and plug them in and out about 50 times. This will clean the tarnished contacts and make your remote sensor start working. Your remote sensor goes through a switch on this jack.
LG 42LC2D 42 in.... | Answered on Nov 12, 2018
Could be an open internal fuse or power supply failure
LG 42LC2D 42 in.... | Answered on Nov 07, 2018
Do a first time installation, move the TV or bite the bullet and either buy an external aerial or extend the main house aerial cable to reach the TV. assuming your TV has no signal where it is now
LG 42LC2D 42 in.... | Answered on Nov 01, 2018
I belive the repair shop might be try to get more money from you
if you enscrew the back of the tv ( with the tv unplugged ) look for a flat wirestrip thats not connected
I think they either forgot to plug in that video wire or they did it to make money from you
did it work fine before the dim screen or did it come back to you like that?
LG 42LC2D 42 in.... | Answered on Oct 29, 2018
unplug the TV. hold down the power button for 30 seconds. plug the TV in.
this worked for me :)
LG 42LC2D 42 in.... | Answered on Aug 19, 2018
15.3 % according to this article:
http://www.thehindubusinessline.com/bline/2002/12/04/stories/2002120400330600.htm
I hope you find this very useful:)
farmerbear
LG 42LC2D 42 in.... | Answered on May 24, 2018
To fix the problem, try turning off the TV and unplugging it from the outlet. Once unplugged, push the power button and hold it down for 1 minute. Then turn the TV back on and rescan for channels.
If the problem persists, contact LG customer service immediately as there is a problem with the memory card. The device is unable to retain scanned channels for immediate feedback.
All LG LCD automatically comes with a 1 year manufacturing warranty. You would have to provide proof of purchase to show when it was purchased. Hope this helps. The Guru
LG customer service: http://www.lg.com/us/support/index.jsp
LG 42LC2D 42 in.... | Answered on Mar 02, 2018
do you have speaker on each side if so move a way from TV
LG 42LC2D 42 in.... | Answered on Feb 13, 2018
It looks like an electrolytic cap. on the power supply. you may find that the guilty one is bulging on the top.
LG 42LC2D 42 in.... | Answered on Jan 24, 2018
unless you have 2 input plugs etc there is no way to do it .
LG 42LC2D 42 in.... | Answered on Jan 17, 2018
Could be start ccts. (main board) or maybe capacitors on the power supply board.
LG 42LC2D 42 in.... | Answered on Jan 15, 2018
this is looking like a common LG problem our tv started doing this tonight
LG 42LC2D 42 in.... | Answered on Jan 13, 2018
LG 42LC2D 42 in. LCD HDTV Logo
3,065 questions posted
Steve Allison
Steve Allison
View Most Popular
  • LG Televison & Video
Most Popular Question
reboot lg tv sound but no picture even
  • Televison & Video
