20 Most Recent LG 32LX1D 32 in. LCD Television Questions & Answers
HDMi cable hooked up, but I get an
you have to go to the input button on the remote and push HDMI
12/7/2019 5:07:26 PM • LG 32LX1D 32 in.... • Answered on Dec 07, 2019
2answers
LG 32LX1D - TV guide preview
For all of you who have this problem, it started when TV GUIDE began to do their conversion to Digital. What you need is an "EPK" file update. I have that file and have no problem emailling it to anyone. I bought a service remote and changed my own main board which I have returned because I found the right solution. LG was no help at all. I am so pleased and happy that I can help anyone. Email me at [email protected] put "TV GUIDE" in the subject line and Ill forward you the file and what you need to do... within 4 minutes you will be back to normal.
3/21/2019 7:22:00 PM • LG 32LX1D 32 in.... • Answered on Mar 21, 2019
LG TV - Memory card failure?
It might be that the memory card is too big or too small - check the specs of the TV in your user manual. I would use the largest memory card that the TV's specs allow.This is explained in the user manual (page 98 in this PDF):https://usermanual.wiki/Lg/Lg26Lx1DUsersManual227300.321404066/helpAlso, you should format a memory card in Windows (FAT format) before placing the memory card in a device.Good luck.
1/20/2018 9:59:51 AM • LG 32LX1D 32 in.... • Answered on Jan 20, 2018
When i plug my lg
Have you tried switching it on using the remote control for your TV? It appears your TV is on standby mode and only the remote might do the trick to get it to fully power on. Post a feedback or update if this tip does not help you out.
10/12/2017 11:23:10 AM • LG 32LX1D 32 in.... • Answered on Oct 12, 2017
LG 32lcd2d
Sounds like your cable is off or your not on chan 3 . Can you go to setup and find cable , air ect ? And see if that does anything ? Check all your coaz and hdmi and make sure they are tight as well
6/25/2017 8:17:44 PM • LG 32LX1D 32 in.... • Answered on Jun 25, 2017
My LG tv wont turn on and the power indicator light isnt on anymore.
Fault to the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
7/7/2015 12:48:23 PM • LG 32LX1D 32 in.... • Answered on Jul 07, 2015
How do you disable the guide plus on a RCA tv?
Go to menu & choose settings. Change the zip code to all zeros. Then choose NO for all questions such as cable, VCR, DVD. This will disable guide plus from coming on when power is turned on.
7/2/2015 2:04:36 PM • LG 32LX1D 32 in.... • Answered on Jul 02, 2015
My lg 32inch plazma tv is showing faint blue on screen without picture.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
2/14/2015 2:15:22 PM • LG 32LX1D 32 in.... • Answered on Feb 14, 2015
L G lcd tv reset
Hello
If you have forget the parential passcode key in [7777] on the remote control. Your LG TV will be unlocked. After unlock, you have to reset with an other passcode. OK.
12/21/2014 6:52:33 PM • LG 32LX1D 32 in.... • Answered on Dec 21, 2014
Have a lg 32in tv that has line on left side of screen
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
11/30/2014 7:54:15 AM • LG 32LX1D 32 in.... • Answered on Nov 30, 2014
2answers
Tv lcd problem
Fault with main board. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too will be necessary.
10/21/2014 9:31:40 AM • LG 32LX1D 32 in.... • Answered on Oct 21, 2014
0answers
0answers
LG 32LX1D 32 in. LCD Television Logo
141 questions posted
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
View Most Popular
  • LG Televison & Video
Most Popular Question
when turned tv all happened
  • Televison & Video
