20 Most Recent Sony FD Trinitron WEGA KV-32FS100 32" TV Questions & Answers
Probably the power supply is failing
Sony FD... | Answered on Jan 06, 2018
Could be a failing power supply
Sony FD... | Answered on Oct 16, 2017
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sony FD... | Answered on Jun 01, 2017
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sony FD... | Answered on Jul 31, 2015
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Sony FD... | Answered on Apr 24, 2015
Main system control memory IC fault. Replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sony FD... | Answered on Mar 06, 2015
You will need a universal remote, however, the master password is 4357. After the master password, you must create a new password, it cannot be used to unlock currenly blocked channels.
Thanks
J
Sony FD... | Answered on Aug 28, 2014
you will need to purchase the the xbox A/V component cables as your tv doesn't have hdmi
Sony FD... | Answered on Jul 15, 2014
pls. use remot menu key and open main menu use DW key and select system menu see the PIP option is "ON" set option is"OFF" .
See the PIP screen is clear.
Sony FD... | Answered on Dec 06, 2013
Do you mean that there is no volume or are you saying that the volume is 'fixed' (not going up or down) or that it was broken but it is now fixed?
Sony FD... | Answered on Dec 01, 2013
It sounds that any electrolytic capacitor at its main power regulator section have bursted out, due to a over-voltage. Contact any service technician. To get more details, http://electronicshelponline.blogspot.com/
Sony FD... | Answered on Nov 23, 2013
Sony FD Trinitron WEGA KV-32FS100 32" TV Logo
245 questions posted
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
sony trinitron xbr 32 inch pip
  • Televison & Video
