20 Most Recent LG 50PX4DR 50 in. Plasma TV Questions & Answers
Are you sure there are no programs saved, you must delete a recorded program to make sure it is unsaved. Also, if it is a controller issue, you may have to leave it unplugged for several days to reset. But this is not a guaranteed fix.
LG 50PX4DR 50... | Answered on Jan 04, 2018
Hi my name is Roety,
I can help you with your issue ,
The cable box signal is received from a round cable called coaxial cable. The guide is sent to the cable box through the coax cable. The HDMI cables sends the picture to the TV.
The Tv does not download TV guide listings , just the box does. That would be a cable company/box issue not a TV issue.
Some TVs have a built in TV guide for when you recieve signals from an antenna (not cable).
If thats what you are referring to don't bother .
Use the cable box guide .
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
LG 50PX4DR 50... | Answered on Dec 03, 2016
Usually when customer reports they heara loud crack and now unit won't power up what we bad is commonly the Y SUSTAIN and LOWER Y DRIVER CBA. hOPEFULLY YOUR UNIT IS UNDER FACTIRY WARRANTY. anyway it goes this is a shop job.
LG 50PX4DR 50... | Answered on Oct 24, 2016
It can be fixed but about $300 in parts.
LG 50PX4DR 50... | Answered on Jun 29, 2016
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
LG 50PX4DR 50... | Answered on Apr 17, 2016
sounds like it may be a software upgrade
LG 50PX4DR 50... | Answered on Apr 28, 2015
Do a re-tune to this set; after a reset. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
First do a hard reset and check. If it do not help you do a factory reset.
LG 50PX4DR 50... | Answered on Nov 04, 2014
You have to format it. Refer its user manual for details. Electro help
LG 50PX4DR 50... | Answered on Oct 28, 2014
Look for button labeled ratio, push as many times as it takes to get right size,usually 16:9. If you are using a cable box/satellite box the pix size could also be adjusted within its menu. but first be sure the TV is properly set to 16:9
LG 50PX4DR 50... | Answered on Oct 21, 2014
LG 50PX4DR 50... | Answered on Oct 09, 2014
Check with your nearest TV dealer around you.
LG 50PX4DR 50... | Answered on Jul 26, 2014
Denise
Have you tried checked the cables, power and knobs?
then try in time settings- in auto sleep, probably set in sleep timer.
kolbrun
LG 50PX4DR 50... | Answered on May 26, 2014
LG 50PX4DR 50 in. Plasma TV Logo
Popular Tags
138 questions posted
Ekse
RONALD CARTER JR
View Most Popular
  • LG Televison & Video
Most Popular Question
main board or side buttons broken
  • Televison & Video
