20 Most Recent
Philips 32PW6506 32" TV Questions & Answers
Frequent but not all times rolling of the picture
Replace all the electrolytic capacitors [ 5 0r 6 of it] at its vertical scan output section circuit. Check the supply filter capacitor connected to the main supply voltage to vertical output IC; and replace it too.
If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic
/ Flip card, can be selected by the drop-down list, by the top left
of the display window, will make surf easy. You can also do a search, by type in the brand name / model
number / IC used, in the search box at the top right of the display window.
No sound in Philips 29 PT 5507/94
HiThe basic approach is to desconnect the tv set from mains, open the case and reach the speaker(s) for test. To do this you can use a l.5V cell case with the cell inside and place the black wire to the negative side of the speaker (-) and touch with the red wire to the positive side (+). You should hear a noise for a good speaker. If no noise the speaker is bad. The advanced approach (that need the tv circuitry schematic) is to trace the sound IC and associated circuits to find out the faulty component..Sully
On my philips tv the red standby light is flashing
hola,tengo un reproductor de musica y a estado parado un tiempo,y ahora al enchufarlo se le enciende la luz de standby en rojo y no en verde como deveria ser.a que es devido este problema?1 saludo y gracias
Ic tda9580h/n1/3/1125 optioncoad
To little information to help and if no sound check speakers on, Does a DVD via rear jacks have sound, and does the set have a headphone jack.
I have a Tv Philips
Good day!
Usually that problem is cause of the failing capacitors on the power supply section.
You have to do is open the back cover of your TV and look for the actual image of the capacitor with in the power supply section if it is leak/bulged on the top.Please replaced it with the same type,ratings and value.
Thank you and good luck.
I changed the cabling between
The only way to change the source for the 28PW8608/05 is to use the remote. On the original remote, just below and to the left of the power button is the button you need. The image on it is a square with an arrow going into the square from one side. The inputs should go TV, EXT1, EXT2, (EXT3 on some models), Front). Depending on the set top box, you may need to enter the setup menu and set the digital source for the input (Press together Fast Rewind and Stop > Setup > Digital Source) or the decorder (next option in Setup).
If you do not have the original remote, you will need universal remote with an input or source button and to find the code that matches the function. Some codes may only operate the basic functions. (The lowest end universal remotes often lack this feature.) A universal remote that can be programmed via a USB connection with a computer will be the fastest to set up.
I hope this helps.
