I have a Wow Pump UltraJet 1.25hp Airswitch 115v 1010111 F35A01A03 for a whirlpool type tub. Haven't run pump for several months but it worked fine last time I used it... Now it won't circulate water. The motor just hums... The motor also gets hot - lack of cooling water flow I would imagine. Any ideas on what to check?
Water level in tub is good. No blocks I can find in lines or pump. No debris in pump I can see.
The impeller and/or motor shaft is stuck or seized. If accessible you can try rotating the motor shaft with a visegrip plier or similar tool to see if it will come lose. Otherwise you should consider having the pump taken out and overhauled. Often the shaft seal begins leaking and result in water damage to the motor bearings. Bearings can be replaced, but compare labor and parts for overhaul to simply replacing the whole pump.
