20 Most Recent Waterco Baker Hydro 80K Btu Titanium Manual Pool Heat Pump Questions & Answers
0answers
Fan Runs But Compressor Does Not kick In Waterco
I had the same problem last week. I called a technician who found out that the capacitor was defective. Cost 50$ + the service call. If the capacitor is working, it might be the compressor...
6/8/2014 10:00:49 PM • Waterco Baker... • Answered on Jun 08, 2014
2answers
Waterco Aqua Heat Titane 101, The Fan Come On But
make sure your filter is clean, heat pumps are fussy about too much back pressure. you might try it with the filter cartdrige renoved
6/8/2014 9:55:27 PM • Waterco Baker... • Answered on Jun 08, 2014
My thermopump is stuck on defrost, it will function for about 15 min and then gets stuck on defrost. How can I fix it?
I ve got the same prblm ,I ve lread changed thermosensor and condensator no change
8/24/2013 1:34:42 AM • Waterco Baker... • Answered on Aug 24, 2013
I have a waterco titanium pool heater water is pouring out of drain holes in the bottom of unit.I have to keep filling up the pool every other day.what do u think is causing the water to puor out like
in which area do you live, as if the air temp is colder than the pool water it is evapoartion most likely, Test the water coming out of the heater against the water in the pool, if your pool is salt water and the water coming from the heater has no salt then your pool is not leaking, as the heat pump is like an air conditioner it will produce condensate Water from the air. in steamy weather there will be alot of water. David PoolWerx Brisbane
3/10/2013 8:28:16 AM • Waterco Baker... • Answered on Mar 10, 2013
0answers
0answers
My heatpump, a Waterco Aqua Heat XL Titane 101, now display error code "ot". What does it means and how can it be fixed?
I think that replacing the temp sensor will solve this problem.
6/8/2021 3:31:29 PM • Waterco Pool &... • Answered on Jun 08, 2021
Waterco pool heat pump displays error code "ot"
Pull thermistor out and clean it with rubbing alcohol and reseat it. Reseat all wire, harnesses, plugs, relays, etc. that are attached to it.
11/25/2020 12:10:13 PM • Waterco Pool &... • Answered on Nov 25, 2020
Error code on my waterco titanium pool water heater says nFL.
NFL code: No water flow, not sufficient water flow through the pool heat pump or the water pressure switch needs to be adjusted or is defective.
5/8/2020 11:08:44 PM • Waterco Pool &... • Answered on May 08, 2020
Hi have a waterco supastream 150 pool pump. When turned on it makes a humming noise doesnt pump, but if you switch it on and off a few times it fires up. What could be the problem? Regards Nicky
Will either be the start capacitor (in the box on top of the motor) or something binding the impeller or potentially both. There is a fan cowling on the rear end of the pump try this; - Turn the power off - Remove the cowling - See if the fan allows you to spin freely/easily the pump BE SURE nothing could become entangled in the fan - Turn pump back on - If it starts, probably something on the impeller side - If it doesn't but will start with a little turn of the fan probably the capacitor. Get a new one from Jaycar or RS components Remember to put the cowling back on safely.
3/22/2019 3:03:16 AM • Waterco Pool &... • Answered on Mar 22, 2019
Waterco Baker Hydro 80K Btu Titanium Manual Pool Heat Pump Logo
14 questions posted
Top Waterco Pool & Spa Experts
Jay Finke
Jay Finke
 Mikey
Mikey
Are you a Waterco Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
Waterco Pool & Spa
  • Waterco Pool & Spa
Most Popular Question
waterco aqua heat titane 101 fan come
  • Pool & Spa
