I have a mitsu vs-60609 60" projection tv and the left side of the screen the convergence is out. i re-did the whole screen convergence but the left side from about 12" at the top to 3" at the bottom still is out. can anyone help?
Convergence IC's inside of your TV are nearing end of the life. If during adjustments that you made Red and Blue was moving in all directions (left, right, down, up) than resistors and fuses still probably OK. IC's (part number will start with "STK" and they attached to huge aluminum radiators) have to be replaced and fresh heat sink compound have to be applied.
After that convergence adjustments should not be a problem. And color will stay together for another several years.
regards.
Russ.
Convergence IC (s) are on the heat sink on the center PCB.
Part # Stk392-570 X 2 or Stk393-570
Check soldered-in pico fuses in power supply .
Use first quality parts and good soldering technique and you should be ok...T.
