20 Most Recent
Mitsubishi WT-42311 42" Rear Projection Television Questions & Answers
When I go to turn it on it clicks and then clicks off
do the self check this model has and let me know what you find:
when it shuts off press ON THE FRONT OF THE TV both the menu and input (or device) buttons at the same time for at least five seconds and release both buttons.
The power light will blink a two digit error code.
for example---2 blinks, a pause and 2 blinks (this is the most common error code)
Let me know what code you find and I will tell you what it means and what can be done.
If this helped you rate this solution as I do this here for free.
SD TECH
I have a Mitsubishi Model WT42311 Tv . It will not stay on
Yes, do the self check that this set has.
When you try to turn it on and the power light goes off:
On the front of the set press and hold both MENU and DEVICE (OR INPUT) for 5 seconds and release both buttons.
The power light will blink a two digit error code--for example--2 blinks, a pause and 2 blinks---it will repeat the code at least 5 times.
Let me know what code you find and I will tell you what it means and what may have to be done.
2,2 is the most common and the least expensive to fix.
If this information helps you, rate this solution as I do this here for FREE.
SD TECH
Mitsubishi ws-48311 blue and yellow shadows
I would suggest you go into the menu and select convergence and then advanced convergence (set will display on screen instructions) and call up the grid of lines by doing that---the grid of lines you see should all be yellow---if you see red or blue lines out of position try with the Mitsubishi remote to adjust them.If they will not adjust the set needs the convergence circuit repaired.For many if this is the issue it can be a do it yourself repair--I have complete instructions for this repair in this set---start to finish.Look first to see if this is your problem.SD TECH
How to connect hdmi from the cabel box to the tv
First things first. Does your cable box have a HDMI output on the rear? If so, mearly aquire a HDMI cable from one of your TV electronics retailers and connect it to one of the unused HDMI inputs on your HDTV. Use your TV remote to switch to that HDMI port and POOF.. there you go.
No red color on screen
there are three basic color controlled by electronic circuit, in picture tube gun,one of them not working properly.needs detail analysis
My mitsubishi 42' hd 1080
Have you acessed the power indicator error code by pressing in the menu and input buttons on the front of the set both in together and hold in for 5 seconds? The led will blink a series of blinks to indicate a 2 digit code which will repeat several times. Let me know what the blink seqience is.
Power turns on but within
When the power light comes on and then goes out, on the front of the set press both the MENU and INPUT buttons at the same time and hold them both in for at least 5 seconds and then release both buttons.
The power light will blink a 2 digit error code and repeat it at least 5 times.
The most common error will be 2 blinks, 2 blinks- a pause and then it will repeat it for a total of at least 5 times.
To get it to repeat this--you have to unplug the set, try to turn it on again and repeat the process.
The error codes are to try to narrow down where the problem is.
Let me know what error code you find, I will tell you what it means.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Have a WT-42311 TV. It shows red and green out
The two convergence IC's are going to have to be replaced---possible do it yourself if you have some skill and can solder.
The reason this happens is simple: This set should use two of the STK-392-110 chips, they have a metal back and when installed a white grease to transfer heat to the metal they are bolted to is applied.
After some time the heat dries out the grease and one of the chips reaches a point where it cannot move the heat to the metal fast enough and fails.
Someone who can get at them (I can tell you how) and can solder (each chip has 18 pins) can do this repair for under 30 dollars total parts cost.
I never know when I answer a question here how much skill the person asking has.
Let me know if you have some skills and I will tell you what to do.
A reply here as a comment will result in the site sending me an email.
SD TECH----here to help.
Mitsubishi ws-55311 red convergence is
The convergence IC chip or chips need to be replaced. Sometimes you can find them on Ebay pretty cheep. Sometimes just buying a used working board is less of a hassle. These chips will have a number like ST 393570 (Just an example). And they would be almost the length of your thumb. It will work but keep in mind soldering can be tough if you heat these up too much in the process of soldering? They will fry.
Red shadows
Most likely it is a convergence issue. Have u tried to converge red and Blue?
When i press power the timer light flashes and the
If model number is WT-42311 do the self check the set has.
When power light comes on and then goes off, on front of set press both the Menu and Input (device) buttons at the same time and hold for at least 5 seconds and then release both buttons.
Power light will blink a two digit error code like: 2 blinks, 2 blinks, a pause and the repeat the code several times.
Let me know what the error code is and I will tell you what it means.
If this has helped you, rate this solution as very helpful as I do this here for free.
SD TECH
FINE LINES HORIZONTALLY ACROSS SCREEN, ABOUT 2
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as
www.TvRepairKits.com
