20 Most Recent Mitsubishi VS-60609 60" Rear Projection Television Questions & Answers
try a reset .open back make sure lights are clean and all blinking there is red green blue . leave unplugged for few hours it should factory reset
If you need further help, I’m available over the phone at https://www.6ya.com/expert/richard_b59056c0c62ecb00
Mitsubishi... | Answered on Aug 05, 2014
Hello, cleaning may help, but I would bet the coolant in the crt's is mildewed, a common issue with Phillips projection sets. you can unplug and remove the back cover and get to the lens assembly to clean them with a lint free towel and glass cleaner, spray the towel and wipe them all 3 off and dry with a clean towel and re-install the back cover and see if that helped. If it didn't it's the coolant in the crt's that will need to be changed by a technician. tks
Mitsubishi... | Answered on Nov 09, 2013
Your convergence chips likely failed and shorted out. This will cause many project TV sets to shut down to protect themselves from any damage. Take a look at this fixa page for more details or goto the site www.TvRepairKits.com for parts and instructions. Here is the fixya link http://www.fixya.com/support/r11932741-convergence_repair_dull_video_repair
Mitsubishi... | Answered on May 25, 2013
Google for the Service manual which will have a schematic and a parts list try Scribed
Mitsubishi... | Answered on Dec 23, 2012
Does the set if model listed here is correct come on with the green power light for a few seconds and then that goes off?
Mitsubishi... | Answered on Dec 22, 2012
go to T.V. manufacteror's web site see what they say or, go to dollar general and pick up a universal remote of the same brand as your T.V.
Mitsubishi... | Answered on Jul 15, 2012
almost everything is fixable---
Remove entire light box
Aquire service manual with schematics
Begin testing for first the voltages in that area and then for any signs of damage from Glycol leakage.
May not be a do it yourself repair as also need a meter to check voltages and resistance etc.
Mitsubishi... | Answered on Jun 13, 2012
Por favor habla en English?
Mitsubishi... | Answered on Jun 07, 2012
You will need to replace IC8c00 (STK 393-110) . This is your convergence IC. You will need to measure all of the 6.8 ohm resistors, replace as necessary. These resistors will have blue,gray and gold stripes, there may be sixteen of these. Expect to replace at least three of these if not more. Replace caps C8c05 (25 volts at 100Mf),C8c07 (25 volts at 100Mf). Other caps to replace are C2c86 (25 volt at 10Mf),C2V17 (25 volt at 10 MF) and C601 (350 volt at 1 Mf). you will also need a keen eye to resolder connections behind tuner TU1A02 (says RF). Jumper sockets CE,RG,DM,VU,DP,EL. Check and resolder socket connections KC,KB,AV1,AV2 and resolder IC 2p30. And you will also need to pull the power supply board, resolder jumper connections CE, RG, DM, VU, DP, and EL. Resolder the vertical IC , this IC will be of the LA78XX series,(do not use excess solder and short the pins). Resolder the horizontal transformer, and the flyback transformer. You will need a keen eye to visually inspect bad grounds on power resistors,horizontal transistor, horizontal output transistor any any and all regulator transistors located on heat sinks. This may seem complicated, time and patience will repair this. Spend an hour a day for two weeks to fix this. Thanks for asking and show all hands of support!
Mitsubishi... | Answered on Sep 29, 2011
Ur tv convergence board that was replaced for ur tv.The 2 STK convergence ICS was old it is not new it is those 2 STK convergence ICS on the tv convegence board is dead again and some of the resistors on the board maybe shorted and dies also must replaced too.The tv convegence board was put on ur tv those parts on the convergence board are old components parts,ur must repair tv convergence board again to fixed this problems called convergence pictures problems.
Mitsubishi... | Answered on Aug 22, 2011
Mitsubishi VS-60609 60" Rear Projection Television Logo
130 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Mitsubishi Televison & Video
Most Popular Question
mitsubishi 60inch
  • Televison & Video
