Acer AL1914 19" LCD Monitor Logo
Posted on Mar 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Acer monitor will not work, not light no
Acer monitor will not work, no light no nothing , when i plug it in no green light, took apart checked fuse it is good, any ideas
Bud Martin
Level 3:
  • Master 11,361 Answers
  • Posted on Mar 19, 2010
Bud Martin
Master
Level 3:
Answers
11361
Questions
Helped
3368973
Points
33650
The capacitors are good, no bulging top/seal? Pictures? see example of failed monitors: http://s807.photobucket.com/home/budm/allalbums
Pictures will help a lot.
Why is the power light on my Acer monitor flashing?
See this.. http://www.techsupportforum.com/forums/f25/acer-monitor-is-blank-and-power-light-flashing-green-318760.html
Also, here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
2helpful
4answers
Monitor black but power light blink green
The 470uF 25 Volts capacitors on the power supply board are probably bad. Replace them all and tell us the result !
I had to take my computer in for repair and turned the acer monitor off while the tower was gone. After plugging everything back in after repair, the monitor will not come on when you hit the power...
The first thing to check is , the Power, are ya sure it's plugged in OK, are ya sure that socket is working, try something else in that outlet to prove, check the power cord is pushed right in, Check ya on the right Video connector on the PC, make sure all conns are correct. Try the monitor on another base unit, try your base unit on another monitor. If all these are OK then ya Monitor has turned it's toes up sorry.
1helpful
2answers
Acer AL1716 Power problem?
i have experienced the same problem (power cycles on and off and on and off... nothing but Acer logo and black screen) on 2 Acer model 1706 A version 1706 Ab monitors both built in July 2006. Before the customer reported the 2nd monitor with the same problem, i sent the 1st one into Acer for warranty service (after testing in on 4 machines w/4 different video cards). They shipped it back with a paper saying the monitor was repaired. I returned the monitor to the customer and it exhibited the same symptoms (aka, not repaired). Could there have been a bad batch in July 2006? When I plug a new Acer AL1716 monitor into the same computers, I have no problems at all.
Acer al1714
The problem may not be the monitor. Acer AL1714 is known for its weak power supply unit. Unplug power supply from monitor. If the green light on monitor comes on but goes out quickly, the power supply is the culprit!
Monitor not getting power
could you describe how you got it apart? i've got the same problem, and i feel like i'm going to crack it just to get it open...i've mostly tried pulling the back off from the bottom after removing the 2 screws
thanks
Intermittent power on problem, monitor now completely dead
See other post regarding IC901 Please feel free to RATE me if it helps
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
