20 Most Recent Acer AL1914 19" LCD Monitor Questions & Answers
The usual suspects, blown fuse, blown capacitors, bad solder joints. Any of this conditions could be your problem.
Acer AL1914 19"... | Answered on Feb 20, 2019
Sounds as if screen is going out..
Acer AL1914 19"... | Answered on Apr 02, 2018
There is a setting on the computer screen, it will say vertical and horizontal shift, There is buttons on the monitor to get to the menu to get to screen shift settings.
Acer AL1914 19"... | Answered on Mar 07, 2015
When you have starnge problem like this, first place to check will be the power supply, if it is not putting out clean DC you will get strange problem. See pictures of failed ACER due to bad caps here:
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Acer AL1914 19"... | Answered on Jan 27, 2015
Try checking the setup of your computer for this issue (CMOS) check if the dual sreen option is enabled
Move anything magnetic away from your screen. Including speakers.
Click on menu button on the monitor.
Acer AL1914 19"... | Answered on Jul 28, 2014
Are you logging in on a secondary login? This might be why....I don't know what operating system you have but you should go to control panel and the go to users. You must create your own user name to login to, or if you have been using this other persons for a while and downloaded anything to their user name...I would see if you can edit the user name you have been using and type in your name then"..once you create a new user name you are going to have to create everything you have been using on the other persons login and copy to the new login.
Acer AL1914 19"... | Answered on Jul 27, 2014
You remove the stand and all the screws, then use the flat blade screw driver to crack open the case, srating at the bottom center and work your way around. When you get the bottom side and the left and right side crack open just enough, lay the monitor face down on soft surface then lift up the back cover to release the top side edge.
Be real careful on the cable attached to the front bezel.
See example here; http://s807.photobucket.com/albums/yy352/budm/ACER/
Make sure to replace the caps in a set using low ESR type caps.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Acer AL1914 19"... | Answered on Jul 14, 2011
http://www.retrevo.com/support/Acer-AL1914-Monitors-manual/id/719ag117/t/2/
Click on the above link and download the manual.
Please don't forget to rate this answer.
Acer AL1914 19"... | Answered on Apr 11, 2011
Acer AL1914 19" LCD Monitor Logo
82 questions posted
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
View Most Popular
AL Acer
  • AL Acer
Most Popular Question
acer al1914 manual
  • Computers & Internet
