20 Most Recent Acer 22" X223w LCD Monitor Questions & Answers
Flat cable inside of the monitor is bad. that's happen when things are not used for months or years, Water condezation is damaging the cable or board!
Acer 22" X223w... | Answered on Dec 13, 2018
can you post an image that shows what you are referring to?
Acer 22" X223w... | Answered on Jan 07, 2018
hi Samuel.
this is all i could find from the internet.
You can try a power reset to see if that helps. To do a power reset, unplug the power cable and press and hold the power key for 10 seconds. Then, release the power key and plug the monitor in and attempt to use it. If you are still unable to get a proper display, We would suggest contacting technical support to inquire about warranty repair options. Many of our monitors carry a 3 year warranty, so there is a chance you may still have warranty left.
Acer Service and Support
you could also try this link out.
Acer 22 X223w LCD Monitor will not start up Google Search
Acer 22" X223w... | Answered on Dec 14, 2017
test with dvi cable or other vga cable first. sometimes bios may cause this problem.
Acer 22" X223w... | Answered on Aug 05, 2016
Why don't you contact Acer and pose that question to them?
Acer 22" X223w... | Answered on Apr 07, 2015
There is an "inverter" component inside the LCD monitor,
that creates all the "brightness" of the image.
That part is failing, and is becoming intermittent.
It's about a $20 part to replace, plus $50 for a qualified TV/computer technician to open the monitor, replace the part, and reassemble the monitor.
Acer 22" X223w... | Answered on Mar 26, 2015
There should be buttons somewhere on your monitor...one named 'Menu' there you should click on an option to change the positioning or horizontal/vertical then follow the instructions...usually the arrow keys...to move the frame to where you need it...hope I helped!
Acer 22" X223w... | Answered on Jan 13, 2015
you need click on your monitor options down on your sys tray in the right hand corner, right click and there will be your options on rotating your screen
Acer 22" X223w... | Answered on Dec 22, 2014
Hi..there,
If you wanted to be crystal clear... Try using a DVI cable if your monitor got these function. Happy Holidays!
Acer 22" X223w... | Answered on Nov 30, 2014
Does your video-card allow you to set a resolution of 1680 by 1050?
(This is exactly 16 pixels horizontally for each 10 pixels vertically.)
This is the "native" resolution of the X223W monitor.
If not, pick a supported resolution that keeps the 16-to-10 ratio.
You would only need that cable if the other end requires a VGA end. Happy Holidays
User manual: http://www.retrevo.com/support/Acer-X223W-Monitors-manual/id/23224ci553/t/2/
That is normal condition, yellow = no video signal from PC since PC is off or PC in standby mode.
The backlight controller has failed. It can be repaired or replaced.
try changing video cable
visit this website for technical support:www.pcworld.idg.com.au/review/monitors/acer/x223w/220722
Change the screen resolution properties.
Acer 22" X223w LCD Monitor Logo
262 questions posted
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
View Most Popular
  • Acer Computers & Internet
Most Popular Question
red green vertical lines appear right
  • Computers & Internet
