The clock thinks it is in a different time zone. Take the battery out.
Replace the battery in the evening, not the daytime. Press the CT button and place the clock near the window facing Colorado. Make sure it is 6 feet from a computer, TV or Microwave while you are trying to set it.
If this does not work:
With the battery still in the clock, try pressing the unmarked tiny DST button for one second. See if the clock advances to the correct Fall time (One hour behind) then press it for one second to turn on DST.
I hope this helps.
Thank you for using FixYa.
Did you try adjusting the time manually? Did you adjust the time zone/ city setting on them as well? If you need further assistance give me the exact model and i can assist you further.
Thank you,
Lee
1. How do I reset it manually?
2. I did push the CT button - it has no "city setting"
3. Model #?. On the back it says WWVB Atomic Clock - is that the model?
It's 8:58 p.m. here, the clock thinks it's 6:58
