20 Most Recent La Crosse Projection Alarm Clock with Temperature and Humidity Display Questions & Answers
If you have storm windows, put it between the window and the storm window.
Or try just below the overhang of your house.
La Crosse... | Answered on Feb 25, 2019
1) Does the remote have batteries? See other posts that describe how to do this (4 screws in back need to be removed). Temperature should be displayed in small window of the sending unit if it's working.
2) Hold Channel button for 3 seconds until it beeps - the unit then searches for a signal.
La Crosse... | Answered on Dec 16, 2018
https://www.lacrossetechnology.com/support/manuals.php
3N6 its the technology named , but the model you can choose can be find on this site .
Mabe the model and page are find on these pictures.
la crosse 3n6 Google zoeken
La Crosse... | Answered on Feb 18, 2016
do a search on Google MAKE,MODEL,manual in search box
La Crosse... | Answered on Nov 01, 2015
low temperature/low humidity (LL)
La Crosse... | Answered on Apr 07, 2015
Once the batteries are installed in the remote the temp will appear in the LED screen. Now you are ready to link signals between the main unit and the remote. Simply remove one of the two triple A batteries from the main unit and then replace. You should then see what appears to be a flashing object shaped like a kite with a tail while the two units link up. Then you should see the temp reading at the remote appear in the LED readout at the main unit. By the way there is also a very small reset at the top of the switches on the back of the main unit that can be depressed with a SMALL pointed object like a scissor point or safety pin point.
La Crosse... | Answered on Apr 18, 2011
You might find it and links to the manual here.
http://www.klockit.com/depts/AtomicClocks/dept-52.html
Strangely, the lacorss site itself downs't have a link to the manuals.
Go figure.
http://www.lacrosse-clock.com/lacrossetechnologyatlacrosseclock.htm
La Crosse... | Answered on Feb 13, 2011
To turn off alarm press ALM1 button for a second.
For time follow instructions here
http://www.lacrossetechnology.com/5432twc/manual.pdf
La Crosse... | Answered on Jan 28, 2010
Just press ALM1 button for a second and it will be turned OFF. Do the same for ALM2.
Did you put two AAA batteries in the remote? Use a small phillips to take the cover off of it. Then hold channel on the main unit for three seconds to synch it with the remote.
La Crosse... | Answered on Jan 04, 2010
La Crosse Projection Alarm Clock with Temperature and Humidity Display Logo
29 questions posted
Top La Crosse Audio Players & Recorders Experts
Steve Allison
Steve Allison
Are you a La Crosse Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • La Crosse Audio Players & Recorders
Most Popular Question
shift 3 projection alarm clock cannot
  • Audio Players & Recorders
