20 Most Recent La Crosse Radio Controlled Atomic Clock Questions & Answers
Hello, William -
If you are asking about a La Crosse Technology Atomic Clock, then . . . see the instructions (24 page PDF document, Adobe Acrobat Reader software - free - needed) here:
https://www.lacrossetechnology.com/media/catalog/product/5/1/512-811-bbb.pdf
Best wishes.
La Crosse Radio... | Answered on Nov 04, 2018
A bit of wd40 or similar in the working gears, they get a bit of something in there and clog, in kitchens they get fat deposits..
La Crosse Radio... | Answered on Mar 05, 2018
The transmitter may be mounted in a location subject to exposure to the elements or sunlight.
La Crosse Radio... | Answered on Feb 05, 2018
Pressing the "regional" button should correct the problem.
La Crosse Radio... | Answered on Dec 26, 2017
I have the same problem with my 16" analog La Crosse wall clock - it was adding 30 minutes to the time every time I set it manually because, even in manual mode, it will continue to search for the signal. Mine is the WT-3161BL with blue dial. This series of clock, which are still being sold with a black and a white dial, have only mediocre reviews on Amazon. Users report they are unreliable or reliable for only a couple of years before they become incapable of keeping time. Others have received their radio-controlled clocks - as I did - with the hands disconnected (because they're flimsy). They are very nice looking (with a stainless bezel) but quality control, not failure to understand the directions, is the greater issue.
I am responding to this post even though it is old because these clocks are still being sold - and not cheaply, in most cases, either. It would be nice if someone could PUBLISH the La Crosse instructions for re-calibrating these clocks. Why? Because from my own attempts to repair this clock I think the issue is that the hands, especially if they become misaligned or fall off in shipping and are subsequently reattached, are not in sync with what the circuit board is configured to "understand" as the 12, 4, and 8 o'clock positions. What this means is that when you select your time zone it may not, in fact, advance to one of the above-indicated times and await the signal. It may advance in a seemingly random fashion. It's not random rather the hands are not aligned with what the circuitry expects to be the 12, 4 and 8 o'clock position. If this is the case no matter what time zone you select or how good your radio reception it will never "catch" the correct time.
I have seen references in some of the Amazon reviews for those who obtained warranty service that La Crosse Technologies "calibrates" it and then sends it back. If I had to guess, calibration of a radio-controlled (analog!) clock involves aligning the hands to the position the circuitry "expects" to be the default (factory) preset. If that is correct, pushing the Time Zone button will allow it to advance the correct number of revolutions. If the hands are not in the factory defaults due to shipping damage or a defect with the assembly, it will continue to set itself incorrectly.
What is frustrating about La Crosse Technology radio control analog clock design is that "Manual Set" continues, nonetheless, to engage the atomic time signal. So even if you compensate by setting the time manually it will, as it states in the user manual, continue to "search". When it thinks it receives a signal it will reset the time, if only partially. This accounts for why, when the radio signal is not strong enough, that these clocks cannot seem to "keep time". It also accounts for why, when they are assembled incorrectly or otherwise damaged (or repaired by re-attaching the hands) that it still cannot keep time.
If La Crosse would simply design their analog wall clocks so that Manual Set DOES NOT continue to search for the atomic time radio signal it would FIX a lot of the issues encountered by owners who A) received a damaged or defective radio-controlled wall clock, and B) those who do not have good atomic signal strength in their location but for which the clock continues to attempt to make use of an intermittent (incomplete) signal. Alas, this is not how La Crosse Technologies designs these analog clocks to function in Manual Set mode, so when the signal is too weak or the hands are misaligned it will continue to try to reset itself but inevitably to the WRONG TIME. (My suggestion to the manufacturer is that they design these clocks to at least have the option to go on working correctly in Manual time set mode, as opposed to having one linked to the other in such a way that when the Radio Control fails the Manual set options also go awry.) Alas, the only real solution that I know of, short of someone obtaining La Crosse Technologies factory calibration instructions, is to DIY replace the radio-controlled quartz module with an aftermarket (non-radio) mechanism. Otherwise, a good percentage of these clocks that did not survive shipping or were not assembled well to begin with will not hold the time.
La Crosse Radio... | Answered on Oct 22, 2017
Try Googling (LaCrosse)(WS916OU-IT)(manual) without parens.
La Crosse Radio... | Answered on Jun 25, 2017
SkyScan 86715:
>Press "SET" once,
>>press "+" until you see your time zone;
-4 ATL-Atlantic
-5 EST-Eastern
-6 CST-Central
-7 MST-Mountain
-8 PST-Pacific
-9 ALA-Alaska
-10
-11
-12
-6MT-?
>Press "SET" once,
DST ON/Off
>Press "SET" once,
US - duh, huh
F - MER-Mercredi, French
E - MIE-Miércoles, Spanish
>Press "SET" once,
>>press "+", for correct hour
>Press "SET" once,
>>press "+", for correct minute
>Press "SET" once,
Range 00-20; 09 = 2009
>Press "SET" once,
Month
>Press "SET" once,
Day
>Press "SET" once,
Day of the Week
>Press "SET" once,
12 or 24 hour
>Press "SET" once,
Fahrenheit or Celsius
>Press "SET" once again - DONE!!!
The clock should now display "month/day/day of the week/moon phase/Temperature"
NOTE: Moon phase and Seconds will correct on first reception from Coordinated Universal Time (UTC)
Lastly,
Press "+" once,
Temperature changes to seconds
>>Press "+" once,
Temperature returns on right-most panel and
seconds replaces day of the week.
>>Press "+" one last time and you are back to done!!!
Thanks,
peppermyers@yahoo.com
La Crosse Radio... | Answered on Nov 02, 2016
There is a nut on the shaft that holds the hands. It has loosened. You will have to disassemble the whole clock out of the case to access that nut
La Crosse Radio... | Answered on Aug 23, 2016
I do not have the same clock, but I assume the atomic receiver is the same. I found my clock went berserk if it was anywhere near anything else electronic. I had it on a dresser that was sharing space with my wireless printer. Once I relocated the printer, the clock went back to normal. You may have a different issue, but maybe check that nothing is around that would cause interference.
La Crosse Radio... | Answered on Apr 27, 2016
Make sure they are both set to the same channel (normally channel 1) put them next to each other then press reset on the temperature unit only.
www.serendipity-gifts.co.uk
La Crosse Radio... | Answered on Dec 28, 2014
If you have not talked to La Cross and if you continue to have the problem, most likely it may be a signal problem. I had a similar
problem with an earlier model and found that it only worked on
the west facing wall as the signal is coming from WWVB which is the NISTtime signal radio station near Fort Collins, Colorado. Get a fresh battery, reset the clock, put it in a west facing window and leave it overnight. If it doesn't work, contact La Cross as above post.
La Crosse Radio... | Answered on Dec 24, 2014
Is the picture the type of clock your referring to? If so you cant set the time zone on that type of clock. You can change the time though.
La Crosse Radio... | Answered on Nov 05, 2014
I'm not totally sure what you mean by "reset the time" because the unit normally sets the time automatically from the WWVB radio time signal. If you want to do it manually, this is what the Instruction Manual (PDF format) says:
MANUAL TIME SETTING
In case the atomic clock is not able to detect the WWVB-signal (disturbances, transmitting distance, etc.), the time can be manually set. The clock will then work as a normal Quartz clock.
  1. The hour digits will start flashing in the upper LCD.
  2. Select the desired hours by pressing and releasing the + key.
  3. Press and release the SET key to advance to the minutes setting.
  4. Now the minute digits will start flashing.
  5. Select the desired minutes by pressing and releasing the + key. If the + key is held, the units
    will increase by 5.
  6. Press and release the SET key to confirm the Time setting and continue to the Year setting.
these really aren't atomic clocks and are set at the factory. It receives, it's LF signal out of Colorado and should correct itself. If not contact the manufacturer.
La Crosse Radio... | Answered on Oct 29, 2014
La Crosse Radio Controlled Atomic Clock Logo
213 questions posted
Top La Crosse Home Experts
Steve Allison
Steve Allison
Are you a La Crosse Home Expert? Answer questions, earn points and help others
View Most Popular
La Crosse Home
  • La Crosse Home
Most Popular Question
hands rotate endlessly onatomic clock wt
  • Home
