Frigidaire Affinity ATF7000E Front Load Washer Logo
Posted on Mar 06, 2010
Resolved QuestionShow me another » What
Resolved QuestionShow me another » What does EFO mean? It shows as an error message on my washer?
I have a Frigidaire Affinity front load washer. Occasionally the screen shows an EFO message and all the lights flash. I looked in the paperwork and went online. Can't find an answer!
Einar Axel Gustavsson
Level 1:
New Friend:
  • Contributor 12 Answers
  • Posted on Mar 07, 2010
Contributor
Level 1:
New Friend:
Answers
12
Questions
0
Helped
12411
Points
20
Efo enter prblem what is the problem
Affinity washer flashing EFO
Good Morning Friend,
I understand that your Frigidaire Affinity washer, model# ATF7000E, is flashing an EFO code. I do not show an EFO code for your appliance.
I do show an EF1 code, which means the drain pump is clogged. In this instance you would unclog the drain pump.
I also show an EF2 code, which means too much soap was used. All you would do for this would be to try using less soap.
It could also be a false error code. I suggest resetting your washer, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. When you restore power, start any cycle on your washer. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
4helpful
I am getting a EFO then E10 error message after I start a load of clothes...which means I have to cancel the load.
E10/EFO error code is an indication of a slow fill, took to long to fill, no fill or the fill water could be siphoning out the drain hose as it's filling with water.
Check to make sure that the drain hose is not stuck too far down the stand pipe and causing the water to siphon out. Check the cold and hot water supply to the washer for any restrictions. If you have a slow fill remove the hoses from the washer and check for restricted filter screens in the water inlet valve. Check for any restricted hose screens too.
EFO code cameup.
Its not EFO its EF0 .Theremust be some thing blocking the pump .For example socks,underwear etc. The water was not cycling through properly. Cleaned it out and everything works fine.Use proper detergent mentioned for your model because even SUD formation can cause this error.
My washer at the end of all the washing, spinning..etc...display the code EFO and all lights are opened...what does it mean. and I would to know if there is a listing of all the error codes and the meaning...
1helpful
Error messages
Frigidaire, Zanussi, AEG, & More....
EFO = Filter Blocked (low flow) and it is accessible from the bottom front of the machine.
1. there is a blockage in the filter or drain hose.takes too long to drain out.
2. over dosing of powder or liquid. again can cause an air lock in the pump which slows the drain pump down.
Check the filter and drain hose and test again. this fault will only come up at the end of a cycle.
You do not need to reset the machine to get rid of the fault code as this is automatically deleted.
Run an empty load with no detergent in an attempt to get rid of the code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
3helpful
Flashing EFO error code
spoke with electrolux and they tell me that it is over sudsing problem. The washer must use HE detergent or use only a the lowest amount on the cup.
2helpful
Front loading washer
I don't see either of those error codes in the frigidaire technical data for this model. You can look here:
http://www.frigidaire.com/support/ResultsPage.asp?strModel=atf6000es&User=&Search=Search
I've heard EFO has to do with oversudsing so if you're using HE soap use less, if you're not you should switch.
6helpful
3answers
Error messages EFO and E10
It is simple. The wrong soap or too much soap will caused EFO to flash. I overfilled the machine with soap by accident. It started flashing with EFO and I went nuts. What could be wrong with it now?! Too much soap or not the right kind of soap will cause this problem.
Plus, I found a sheet of paper that gives the codes.
This is better than when the strainer plug gets filled up and you have to take the machine apart to clean the little strainer.
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
