Can i fix error code E 2 from my printer Canon PIXMA MP140. Please help. Thank you
Error E 2 =>
The machine is out of paper. / Paper does not feed.
Reload paper in the Auto Sheet Feeder and press the Black or Color button.
error E 2 =>
V pÅĆstroji doÅ”el papĆr. / PapĆr se nepodĆ”vĆ”.
VloĀte papĆr znovu do automatickĆ©ho podavaÄe listÅÆ a stisknÄte tlaÄĆtko [Black] (ÄernĆ”) nebo [Color] (BarevnĆ½).
same problem here actually...i have reloaded papers already but still, it wont print...it's actually accepting the paper but it doesnt print
Error E-2 (no papper)
Sering terjadi kalau cartridge tidak berjalan sampai tuntas atau cartridge akan berjalan dari ujung kiri ke ujung kanan tetapi pada kasus ini Cartridge macet atau berhenti di tengah jalan (in the middle way/stuck). just tried to fix the rail way of the cartridge.
The ribbon beside the cartridge path blocke the cartridge to complete the path .Open the printer check the cartridge path and clear the path and printer works fine.
Quite delicate be careful.
Well, i have a problem with the same kind of printer,. I dont know where this hell of a product is coming from but it the printer does not work. It doesn't pull in a sheet of paper as if there is a load of **** jammed inside it. Tried to check but was unfortunate to calibrate the thingy. I can only use its scan feature, that's all.. Too sad I have to give it awayl Looks hopeless...
Tengo una canon pixma mp140 y no le puedo recuperar despues de que me marca E 5
Que hago????
I was having this problem till i check inside and there was a paper on the right said of the printer i took it off and then works normally lol its funny i didnt check there i was like omg im a fool
tenia este problema hasta que mire dentro y habia un papel arrugado en la parte derecha de la impresora lo saque y ahora ya funciona normalmente hahahaa que chistoso me parecio que no mire ahi antes y estaba rayos soy un tonto hahahaha
oh one thing more reload your printer turn off wait 20 seconds then turn it on again well i dont know why 20 seconds lol just becouse the printer need a breath XD
una cosa mas cuando saques el error o estorbo de papel espera 20 segundos y prendelo de nuevo no se por que pero solo para que la impresora respire
El driver que me vino en esta pixma es para maquina mac y yo solo tengo una con window vista y no permite instalar el sofware de instalacion para poder utilizar la maquina.
my pixma mp150 shows
E 2 on its lcd and the alarm light blinks need help!!!
ME TOO
paper not feeding
GRASIAS POR SU AYUDA PERO NO ME SIRVIO DE NADA MI PROBLEMA CONTINUA E2 YA PROVE CON OTROS CARTUCHOS PENSANDO QUE CON UNOS NUEVOS SI ME RESULTARIAN PERO NADA
me aparece en la pantalla error de servicio 5100
la impresora es canonMp140
error code E 5
