I just had this same problem and it was caused by a small plastic seal on the bottom of the door. My friend owns an appliance store and he said this is a common problem for this model of dishwasher. The part was $68 and the labor was $60. I could have easily fixed it myself if I knew what the problem was but he came out and fixed it so I had to pay the $60 for the service call.
The part number on the repair bill is 14633F. I'm not sure if that's the frigidaire part number or the one from my buddy's inventory. Anyway, hope this helps.
Also, one other word of advice........use a little less soap and it won't suds up quite as high, which will help in the mean time.
Sorry about the delay in time in getting back to your problem if not already resolved heres what you can try. Remove the bottom panel and run through a load, to see exactly where leak is coming from, most common place for leak is through the heater hold down brass nuts. They crack and need to be replaced
I have this same problem, but cannot find where to order the heater hold brass nuts. has anyone been able to find the replacements online?
