20 Most Recent Hobart 24 in. LXIH-3 Built-in Dishwasher Questions & Answers
the p3error is an open or shorted booster thermistor.take off btm panel on the right side is the bstr, do when cold and no power to mach.,TURN OFF BREAKER, ON THE UPPER RGT CORNER OF BSTR YOU WILL SEE THE THERMISTOR.unplug from harness use7/16 wrench to unscrew from bstr. well,get new therm.and installyou can get @ any hobart office in your area, part#328994. dont forget to vote, thanks, monomoy
Hobart 24 in.... | Answered 22 hours ago
I just searched and find no information on Hobart machines
Hobart 24 in.... | Answered on Mar 19, 2019
im a service tech for hobart,there are no adjustments,the torsion bar is broken.the parts arent expensive but installing them are tricky.
Hobart 24 in.... | Answered on Jan 05, 2018
E5 is a drain error - machine is not draining - check drain hoses - pull out machine if needed - check air gap. hope this helps. jimmy.
Hobart 24 in.... | Answered on Nov 22, 2017
Hi drogers77,
I'm not a Hobart technician, but here what I founded in my manual for the LX30 error message:
LX18 / LX30 display shows E0, E2, E3 or E4
1. Low water pressure - check for clogged hose strainer; check that site water pressure meets minimum flow pressures.
2. Make sure probes are clean
3. No water pressure - main water supply valves may not be working
4. Drain valve open - turn machine OFF to drain machine, then ON. Repeat twice (this assists in clearing any drain valve obstructions). Wait for machine to reach READY mode and press WASH. Slowly open door several seconds later and note water level. Close door; 30 seconds later, open door slowly and check that water level is the same as it was. If not, repeat the OFF-ON procedure. If problem persists, call your local Hobart Service Office.
5. Delime machine.
Hope it will help you.
pepsicrazy
Hobart 24 in.... | Answered on Jul 28, 2017
my dishwasher Hobart LX 30 will not shut off and displays 30
Hobart 24 in.... | Answered on Jul 06, 2017
Have you run Delimer through it ? delime cycle?
Hobart 24 in.... | Answered on Oct 18, 2016
It seems that the rinse probe thermistor open or shorted.
Follow the wires for the contactor coil one of them is connected to a resetable hi limit, press the button on the hi limit to reset
Hobart 24 in.... | Answered on Apr 24, 2016
Depending on how often you delime the dishwasher use 2 cups.The delime light will come on after 1000 cycles set from factory default.If the delime icon is lit and beeps,turn the unit off.
Push and hold the delime/wash button and on button for 5 seconds and youll be in delime mode.
The unit will fill and heat up and display "add delime".Open the door add the delime and press the wash button.The dishwasher will run for 5 minutes then rinse and drain twice then shut off.When you turn it back on the delime icon will be gone.I'm a hobart tech and repair these dishwasher often,any questions let me know and please rate me,Thanks.
Hobart 24 in.... | Answered on Apr 21, 2016
The LX18 series was a compromise machine, the lack of a sump heater causes numerous rinse temperature problems due to it's increased water use (over the sump-heater equipped, fresh water rinse LX30 series).
The LX18H can be reprogrammed for true fill and dump operation. If you still need to do this, please let me know via e-mail or post a reply, otherwise a won't post the long answer!
(I worked for Hobart as a service tech. from 1994 until 1999, and have been independent since then)
Hobart 24 in.... | Answered on Feb 11, 2016
This is what I found in the manual...and on a couple of other sites....
Machine won't fill or won't fill high enough(LX18, LX30 display shows "E0," "E2," "E3," or "E4")
1.Low water pressure — check for clogged hose strainer; check that site water pressure meets minimum flow pressures.
2.Make sure probes are clean.
3.No water pressure — main water supply valves may not be working.
4.Drain valve open - turn machine off to drain machine, then on. Repeat twice (this assists in clearing any drain valve obstructions). Wait for machine to reach READY mode and press WASH. Slowly open door several seconds later and note water level. Close door; 30 seconds later, open door slowly and check that water level is the same as it was. If not, repeat the
OFF-ON procedure.
5. Delime machine.
If this doesn't help let me know and I will get to the bottom of it....good luck and thanks for rating my effort...The Fang.
Hobart 24 in.... | Answered on Oct 05, 2015
E5 is water at top probe when starting rinse. If you have burnt smell, it's probably the sump heater on with little or no water over it. Clean and check the 3 probes and their connectors.
Hobart 24 in.... | Answered on Jul 17, 2015
The p2 code is your rinse thermistor is bad,if you gain access in the back on the top right side you will see a probe with 2 wires going into the rinse piping.Use a 7/16 wrench and unscrew.Very easy to replace.When the machine goes into the rinse cycle the temp display goes up/down?The part is about $60.Part # 328994.I'm a hobart tech any ? let me know and please rate me.
Hobart 24 in.... | Answered on Jul 02, 2015
this all I can find Machine will not fill or will not fill high enough. (Display shows E0, E2, E3 or E4. Machine will not run). 1. Low water pressure - check for clogged hose strainer; ensure the site water pressure meets minimum flow pressures. 2. Make sure probes are clean. (See Cleaning.) 3. No water pressure - main water supply valves may not be working. 4. Anti-siphon valve - located in the lower left area of the chamber just above the water line. Drain the machine and insert toothpick or similar object into hole to verify ball (3?16" OD) is free to float. 5. Delime machine perhaps the wax is plugging up the floating ball area
Hobart 24 in.... | Answered on Apr 20, 2015
Hobart 24 in. LXIH-3 Built-in Dishwasher Logo
269 questions posted
Top Hobart Dishwashers Experts
GPEC
Level 1 Expert
Jason
Marvin
Marvin
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Hobart Dishwashers
  • Hobart Dishwashers
Most Popular Question
hobart lxih found leaky hoses replaced
  • Dishwashers
