20 Most Recent Viking DFUD042 Built-in Dishwasher Questions & Answers
Yes I would highly recommend calling for service, there shouldn't be any moisture leaking at all.
Viking DFUD042... | Answered on Dec 04, 2017
I have the same thing, unit pump keeps running, when I pulled it from under the cabinet, if you tilt it back a little it stops, as soon as you lower it back down the pump starts to run again. Getting code as too much water in the tank even though it is empty. PLEASE HELP!!!!!
Viking DFUD042... | Answered on Sep 06, 2015
USUALLY, there is a knob that holds the spray arm on the shaft coming up from the pump. Hold the spray arm and turn the knob the opposite direction than what the arm rotates. there might be a blockage in the shaft which can be seen when the spray arm is removed. the other blockage might be in the inlet to the pump which is on the bottom of the pan where there is a removable screen below which you can see the food/ debris grinder and below that the impeller to the pump. clean out both if you can. Caution - dont leave any screws/ hard items in the impeller cavity.
Viking DFUD042... | Answered on May 07, 2014
go to main power c.breaker an reset it. And try again. Otherwise you must have the instruction manual and read in section troubleshooting how to reset from the machine.
If you do not have download from www. retrevo.com or www.fitness.manualsonline.com
God bless you
Viking DFUD042... | Answered on May 26, 2012
if you open the kick plate, you'll see the pan below the motor and check for leaks. The leaks will trigger the sensor to pump water out. Once you dry out the pan, the pump motor will stop and you should be able to reset the program.
Viking DFUD042... | Answered on Dec 27, 2011
Viking DFUD042 Built-in Dishwasher Logo
70 questions posted
Top Viking Dishwashers Experts
Ekse
Pierre Laplante
Mike
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Viking Dishwashers
  • Viking Dishwashers
Most Popular Question
stuck in drain cycle
  • Dishwashers
