We had two power outages and after the last one, it quit working. I bought the house two years ago and the tub worked perfectly until the last major snow storm. There were no books on the tub so I don't know if it has a reset button on the motor or if something major happened when the power went out. To have it repaired, if necessary, do I call an electrician or plumber?
Hello. There are two reset buttons in the mechanical space or your tub. You should be able to access that area from the front by removing a few screws. it is not uncommon to have to push those reset buttons after a power outage. If you do need a repair I recommend that you call a store that sells hot tubs as they will have a technician on staff or be able to guide you to one. Regards, Joe
PS kindly rate my answer as helpful.
