20 Most Recent American Standard 2770.018w.020 Cadet Whirlpool White Questions & Answers
My pressure relief valve opens, why? I have an
Your expansion tank need air. Bladder might be ripped.either u replace the tank or you drain it cometary and add 12 psi of air
7/2/2017 11:24:15 PM • American... • Answered on Jul 02, 2017
My American Standard whirlpool pump will only hum.
The bearings (or bushings) of the pump or pump motor have siezed, these can be replaced on some models but for the most part you will need to replace the pump and/or pump motor. and as where to get parts, i would suggest the outlet from wich you purchased the unit or another appliance outlet. Or if you feel up to the challenge, im sure you could find replacement parts on the internet: google, ebay, etc.
9/10/2012 2:02:11 AM • American... • Answered on Sep 10, 2012
0answers
I need pump#752538-300 not -0070A
The cheapest one I've found so far was $200. You just need to search differently, try these: http://www.google.com/search?en&q=PUWWSCAS12598R&ie=UTF-8&oe=UTF-8 or http://www.google.com/search?en&q=puwwas1298p&ie=UTF-8&oe=UTF-8
8/26/2011 7:30:47 PM • American... • Answered on Aug 26, 2011
0answers
0answers
0answers
How do i seal the
Be the first to answer 1/13/2011 3:58:36 PM • American... • Posted on Jan 13, 2011Be the first to answer
The on and off button
if you can get to where the motor is..there should be a small plastic hose the inserts into motor...or plug...if you pull the hose off it should allow button to push out again
1/3/2011 4:55:20 AM • American... • Answered on Jan 03, 2011
On of my two front
You need access from the back of the jet. What you do is cut out the old one and install a new one. I suggest that you use a marine grade, under the waterline sealer. Silicone will not work. The under the waterline sealers take several days to cure, but they work. The hoses get glued with a PVC type of sealer that you get from a hot tum place, along with the jets needed.
12/6/2010 9:33:40 PM • American... • Answered on Dec 06, 2010
0answers
When I turn on the whirlpool, black flakes come
Go to a hot tub company, they have scale type cleaners that do this job. It does require draining a few times, but it is worth it.
9/18/2010 3:34:04 AM • American... • Answered on Sep 18, 2010
My bath tub with jets hums and I can't find an access panel.
The pump is usually at the side/rear of the tub, opposite the drain, the faucets can be mounted anywhere, but usually over the drain. The panel could be tiled, and just grouted in, if it is not exposed, try tapping on it to see if it sounds different in spots. Who knows, it might just fall out. How about behind the back wall?? Closet? Access? There is no electrical parts in there to repair, Pretty sure it is just the motor. and a bunch of pipes glued together and stuck through the tub. Did you fill the tub with water before trying the jets? Just checking. Hope this helps.
5/27/2010 1:42:46 AM • American... • Answered on May 27, 2010
Not bubbling
i am assuming this is a jacuzzi make sure the air ports are not clogged it has to **** air to be able to make bubbles
5/10/2010 8:09:45 PM • American... • Answered on May 10, 2010
American Standard 2770.018w.020 Cadet Whirlpool White Logo
Popular Tags
30 questions posted
Top American Standard Home Experts
john h
Mike Cairns
Mike Cairns
deton8 von Splosion
Are you an American Standard Home Expert? Answer questions, earn points and help others
View Most Popular
  • American Standard Home
Most Popular Question
two front
  • Home
